Im aware this may be a bit redundant with the way ZFS works (as well as scrubs), however i would still like to know if this is possible to enable, as i do think its something worth enabling/running, even under ZFS.
In addition to smart short/long/conv. tests, most SAS drives, internally, have a background medium scan that can be enabled. (espesically as i have mostly SAS SSD enterprise drives in freenas)
I know i can pull drives, put them in ubuntu, enable background medium scans via sdparm, and put them back into Freenas, But is anyone aware of a tool to enable this while drives attached to Freenas, ie via FN cli?
ie is there an equivalent sdparm tool on FN? (or maybe sg_tools command to enable this?)
I came across this as i was logging the (smartctl -x /dev/daXX > out.txt) for some new HGST SAS SSD drives i had just attached to FN, and noticed that they all had background medium scans , in progress, running in the background - so i began investing this a bit more as none of my existing SAS SSD drives, in freenas, had this enabled.
(the new drives were pulled from a prior machines HW raid card, thus im assuming the raid cards "patrol read" or similar task had enabled this on the ssds)
more info here:
www.reddit.com
(examples of this running/enabled, and not - both drives are on my FN box - i removed alot of the smart output to better highlight the Background scan results section):
Enabled/Running:
DISABLED:
more info here:
Reddit - Please wait for verification
Enabled/Running:
root@freenas:~/trash # smartctl -x /dev/da58
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor: HITACHI
Product: HUSML404 CLAR400
Revision: C337
Compliance: SPC-4
User Capacity: 400,000,000,000 bytes [400 GB]
Logical block size: 512 bytes
Physical block size: 4096 bytes
Rotation Rate: Solid State Device
Transport protocol: SAS (SPL-3)
Background scan results log
Status: scan is active
Accumulated power on time, hours:minutes 26927:50 [1615670 minutes]
Number of background scans performed: 176, scan progress: 95.83%
Number of background medium scans performed: 176
DISABLED:
root@freenas:~/trash # smartctl -x /dev/da6
Vendor: HGST
Product: HSCP0480S5xnNMRI
Revision: 3P02
Compliance: SPC-4
User Capacity: 480,999,997,440 bytes [480 GB]
LU is resource provisioned, LBPRZ=1
Status: no scans active
Accumulated power on time, hours:minutes 37112:01 [2226721 minutes]
Number of background scans performed: 0, scan progress: 0.00%
Number of background medium scans performed: 0
