Restarts when trying to write to it
TerryVog
Lately I have problems when I upload files to my FreeNAS server. I use it for my TimeMachine backups and as a Plex server. TimeMachine tries to copy files to it regularly. Sometimes it works, sometimes it doesn't. Not very repeatable.
The problem with Plex is similar, but easier to reproduce. As soon as I copy a new movie file to it, it starts to copy 100 or 200 MB to it, but then the connection gets lost and a few seconds later the FreeNAS machine reboots.
A few days ago I had an error:
CAM status: ATA Status Error
ATA status: 51 (DRDY SERV ERR), error: 40 (UNC )
I saw on a forum that it was wise to run a test:
smartctl -t long ada0
to figure out which disk was damaged so I could replace it. After running the test, the error is gone. The Alert button is green, the checksums of all my disks is 0, no apparent problem whatsoever. Except that it panics and restarts when I copy a file to it.
What is going on here? How do I troubleshoot this?
I am running FreeNAS-9.3-STABLE-201512121950 on an Intel(R) Core(TM) i3-3240 CPU @ 3.40GHz with 7842MB RAM.
jde
How do you have your pool setup? Did you run the smartctl long test on each of your drives?
Per the forum rules, please post full hardware specs including motherboard.
TerryVog
I hope I understand you right, but I am not sure. I have 4 drives; 3TB each. They are mirrored, so the total capacity is 6TB.
Mirror-1: ada2p2 & ada1p2
Mirror-0: ada3p2 & ada0p2
I don't know if I did each drive. I did smartctl -t long ada0. Does that only do 1? It took almost 7 hours to finish.
jde
You have to run the smart test on each drive by running "smartctl -t long /dev/adaX" where X coresponds to drives 0-3 in your system. 7 hours sounds about right for a long test on 3 GB drives. Before you do the long tests, post the output of "smartctl -a /dev/adaX" in code tags.
TerryVog
The output doesn't fit in the largest shell window and I don't know how to see the topmost part of the output. So here are the bottom parts for each disk.
smartctl -a /dev/ada0:
Extended self-test routine
recommended polling time:        ( 408) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   193   193   051    Pre-fail  Always       -       18638
  3 Spin_Up_Time            0x0027   188   179   021    Pre-fail  Always       -       5558
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       41
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       3964
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       41
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       39
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       66
194 Temperature_Celsius     0x0022   119   112   000    Old_age   Always       -       31
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Interrupted (host reset)      10%      3899         -
smartctl -a /dev/ada1:
recommended polling time:        ( 376) minutes.
SCT capabilities:              (0x10bd) SCT Status supported.
  1 Raw_Read_Error_Rate     0x000f   113   100   006    Pre-fail  Always       -       51844072
  3 Spin_Up_Time            0x0003   094   094   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       14
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   067   060   030    Pre-fail  Always       -       5885017
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       959
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       14
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   099   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0x0022   063   059   045    Old_age   Always       -       37 (Min/Max 35/37)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       13
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       52
194 Temperature_Celsius     0x0022   037   041   000    Old_age   Always       -       37 (0 22 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
smartctl -a /dev/ada2:
recommended polling time:        ( 383) minutes.
  1 Raw_Read_Error_Rate     0x000f   109   099   006    Pre-fail  Always       -       23380200
  7 Seek_Error_Rate         0x000f   068   060   030    Pre-fail  Always       -       6318782
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       4295032833
189 High_Fly_Writes         0x003a   095   095   000    Old_age   Always       -       5
190 Airflow_Temperature_Cel 0x0022   062   057   045    Old_age   Always       -       38 (Min/Max 37/39)
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       51
194 Temperature_Celsius     0x0022   038   043   000    Old_age   Always       -       38 (0 22 0 0 0)
No Errors Logged
smartctl -a /dev/ada3:
Short self-test routine
recommended polling time:        ( 412) minutes.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   192   181   021    Pre-fail  Always       -       5391
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       71
194 Temperature_Celsius     0x0022   114   110   000    Old_age   Always       -       36
No Errors Logged
pirateghost
Unintelligible Geek
You have a Mac, yes?
Use terminal and SSH into your freenas to run commands. The GUI console is crap. Stop using it.
jde
Only ada0 has had any smart test run on it (long test) and it failed to complete. Run "smartctl -t short /dev/adaX" on all the drives. The short test should only take 2-3 minutes to complete. After the tests complete, repost the output in your previous post.
TerryVog
I do have a Mac and I agree that the GUI console has it's problems. I tried "ssh root@192.168.0.53" but it says "Connection refused". I don't know how this should work, so for now I am condemned to use the GUI.
I will run the short smartctl tests first and repost the outputs soon.
jde
Also, what motherboard are you using and how do you have your drives connected (i.e. directly to motherboard, HBA, raid card)?
jde
If you are stuck with the console please run smartctl -i on each of the drives and post the output. This will be the information that has been cut off of -a output you are getting in the console.
pirateghost
Unintelligible Geek
Enable ssh in the services section of freenas as covered in the documentation
TerryVog
Here is the output of smartctl -i for all 4 drives after running smartctl -t short for each:
[root@freenas ~]# smartctl -i /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4NEY94EFT
LU WWN Device Id: 5 0014ee 260038770
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Jan 14 21:41:38 2016 PST
SMART support is: Enabled
[root@freenas ~]# smartctl -i /dev/ada1
Model Family:     Seagate NAS HDD
Device Model:     ST3000VN000-1HJ166
Serial Number:    W6A0V1SH
LU WWN Device Id: 5 000c50 08b8b8c46
Firmware Version: SC60
Rotation Rate:    5900 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Thu Jan 14 21:47:45 2016 PST
[root@freenas ~]# smartctl -i /dev/ada2
Serial Number:    W6A0V22F
LU WWN Device Id: 5 000c50 08b8b6833
Local Time is:    Thu Jan 14 21:55:19 2016 PST
[root@freenas ~]# smartctl -i /dev/ada3
Serial Number:    WD-WCC4NEKJ1J4T
LU WWN Device Id: 5 0014ee 20aaf0e1b
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Thu Jan 14 21:59:34 2016 PST
jde
The -i was needed because the console cut that info off of the output of -a. Post the -a output again. The results of the short tests you just ran will be shown to the bottom of the -a output.
TerryVog
Ah. Okay, sorry and thank you for being patient with me.
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       3966
No Errors Logged
# 1  Short offline       Completed without error       00%      3964         -
# 2  Extended offline    Interrupted (host reset)      10%      3899         -
  1 Raw_Read_Error_Rate     0x000f   113   100   006    Pre-fail  Always       -       53498896
  7 Seek_Error_Rate         0x000f   067   060   030    Pre-fail  Always       -       5895178
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       961
No Errors Logged
# 1  Short offline       Completed without error       00%       960         -
  1 Raw_Read_Error_Rate     0x000f   109   099   006    Pre-fail  Always       -       25119248
  7 Seek_Error_Rate         0x000f   068   060   030    Pre-fail  Always       -       6330094
190 Airflow_Temperature_Cel 0x0022   061   057   045    Old_age   Always       -       39 (Min/Max 37/39)
194 Temperature_Celsius     0x0022   039   043   000    Old_age   Always       -       39 (0 22 0 0 0)
No Errors Logged
No Errors Logged
# 1  Short offline       Completed without error       00%      3966         -
jde
Does your problem occur only when writing to mirror-0; only to mirror -1; or to both?
It looks like ada0 is failing. It's showing a high raw read error rate. Your ada0 & 3 are WD Red drives, with which I am familiar. Ada3 looks o.k. I won't comment on the Seagate drives (ada1&2) other than to say they passed the short test because the seagates report their smart data in a different numerical format than the WDs. You can search the forums and you should be able to find more information on that.
ada0 has less than a 1000 hours on it, so it should still be under warranty. Run a smartctl -t conveyance test (5-10 minutes) and another long test on ada0 and repost the output of smartctl -a.
Best answer: Do what @pirateghost suggested and turn on SSH on the Services screen on FreeNAS. Then SSH in from your Mac, and you'll have scrollback in the terminal. This is something you really need to get working if you're going to be doing anything at the CLI.
Less good, but will work: Add | more to the end of the command: "smartctl -a /dev/ada0 | more". This will stop the output every page and wait for you to hit the space bar.
Edit: You could also post a debug file, which should have all this information. Go to System -> Advanced -> Save Debug in the web GUI.
Edit 2: You really should set up regular SMART tests--short every 1-7 days; long every 1-4 weeks. Make sure the SMART service is configured with your email address to report errors--it's a separate configuration from other email notification.
TerryVog
Sure enough it now shows an error:
Local Time is:    Fri Jan 15 07:42:46 2016 PST
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      ( 113) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (40680) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       3975
194 Temperature_Celsius     0x0022   118   112   000    Old_age   Always       -       32
200 Multi_Zone_Error_Rate   0x0008   185   185   000    Old_age   Offline      -       6240
No Errors Logged
# 1  Extended offline    Completed: read failure       10%      3972         3569139312
# 2  Conveyance offline  Completed without error       00%      3967         -
# 3  Short offline       Completed without error       00%      3964         -
# 4  Extended offline    Interrupted (host reset)      10%      3899         -
What should I do?
  • debug-freenas-20160115070259..tar.zip
Looking through the debug file contents, I see that a crash on 10 Jan was apparently caused by a non-responsive drive, which I think is ada0:
I/O to pool 'TM' appears to be hung on vdev guid 1723728113578766580 at '/dev/gptid/f3ca651f-3c00-11e5-b5da-60a44caefdbd'.
Your drives are running a little warm. ada2 (one of the Seagates) is at 40 deg C, and has seen 48 during its life. For best life, consider 40 C a maximum drive temperature. The rest of the drives are at 37-38.
You have a Realtek NIC. Those are well-known to be garbage, but I don't know how likely it is that this would lead to your machine panicking.
jde
Follow the directions in the freenas documentation on the process for removing and replace the failed drive. http://doc.freenas.org/9.3/freenas_storage.html#replacing-a-failed-drive
Also, it's apparent you don't have automatic smart tests set up in the Tasks menu. You need to set these up and configure email notifications. http://doc.freenas.org/9.3/freenas_tasks.html#s-m-a-r-t-tests
See this thread for a sane schedule for automatic smart tests. https://forums.freenas.org/index.php?threads/scrub-and-smart-testing-schedules.20108/
