I am trying to replicate from 192.168.1.80 (primary nas) to 192.168.1.90 (backup nas).
I deleted pool (backup-14TB-z2) on xxx.90, replaced disks, and created a new pool backup-60TB-z2 on xxx.90
On xxx.80,
- Edited existing replication and replaced 14TB with 60TB and it failed when i tried to run it.
- So, I deleted my old replication task and created a new one, but it is still failing with the following logs:
Could someone offer a suggestion on what to do next?
The error message is kind of suggesting i need to shut something down, I never did this before.
Previously, I would power up the xxx.90 when I wanted to do a backup from xxx.80 to xx.90 and either let the replication run from xxx.80 on its schedule or I would force it from xxx.80.
Did I miss configure the xxx.90 ?
Version:
TrueNAS-SCALE-22.12.2
On xxx.80,
[2023/08/24 16:53:41] INFO [Thread-666] [zettarepl.paramiko.replication_task__task_2] Connected (version 2.0, client OpenSSH_8.4p1)
[2023/08/24 16:53:41] INFO [Thread-666] [zettarepl.paramiko.replication_task__task_2] Authentication (publickey) successful!
[2023/08/24 16:53:47] INFO [replication_task__task_2] [zettarepl.replication.pre_retention] Pre-retention destroying snapshots: []
[2023/08/24 16:53:48] INFO [replication_task__task_2] [zettarepl.replication.run] For replication task 'task_2': doing push from 'jjg-14TB-z2' to 'backup-60TB-z2' of snapshot='auto-2022-01-06_09-36' incremental_base=None include_intermediate=False receive_resume_token=None encryption=False
[2023/08/24 16:53:48] ERROR [replication_task__task_2] [zettarepl.replication.run] For task 'task_2' unhandled replication error ExecException(1, "cannot unmount '/var/db/system/samba4': pool or dataset is busy\n")
File "/usr/lib/python3/dist-packages/zettarepl/replication/run.py", line 181, in run_replication_tasks
retry_contains_partially_complete_state(
File "/usr/lib/python3/dist-packages/zettarepl/replication/partially_complete_state.py", line 16, in retry_contains_partially_complete_state
return func()
... 9 more lines ...
ReplicationProcessRunner(process, monitor).run()
File "/usr/lib/python3/dist-packages/zettarepl/replication/process_runner.py", line 33, in run
raise self.process_exception
File "/usr/lib/python3/dist-packages/zettarepl/replication/process_runner.py", line 37, in _wait_process
self.replication_process.wait()
File "/usr/lib/python3/dist-packages/zettarepl/transport/ssh.py", line 159, in wait
stdout = self.async_exec.wait()
File "/usr/lib/python3/dist-packages/zettarepl/transport/async_exec_tee.py", line 104, in wait
raise ExecException(exit_event.returncode, self.output)
zettarepl.transport.interface.ExecException: cannot unmount '/var/db/system/samba4': pool or dataset is busy
Version:
