Replication failed with "destination has snapshots"
seanm
I periodically physically connect a backup disk and use Tasks > Replication to run a backup. Has worked great generally.
Yesterday though I did what I usually do but it failed with:
Replication "offsite2" failed: Full ZFS replication failed to transfer snapshot tank1@OFFSITE-2022-06-22_11-51 as a whole. The error was: Warning: offsite2/tank1/zvol1: property 'sharenfs' does not apply to datasets of this type Warning: offsite2/tank1/zvol1: property 'mountpoint' does not apply to datasets of this type Warning: offsite2/tank1/zvol1: property 'sharesmb' does not apply to datasets of this type Warning: offsite2/tank1/zvol2: property 'sharenfs' does not apply to datasets of this type Warning: offsite2/tank1/zvol2: property 'mountpoint' does not apply to datasets of this type Warning: offsite2/tank1/zvol2: property 'sharesmb' does not apply to datasets of this type cannot receive new filesystem stream: destination has snapshots (eg. offsite2/tank1/zvol3@OFFSITE-2022-05-02_11-45) must destroy them to overwrite it warning: cannot send 'tank1/zvol3@OFFSITE-2022-06-22_11-51': signal received. The snapshot offsite2/tank1/.system@OFFSITE-2022-06-22_11-51 was not transferred. Please run `zfs destroy offsite2/tank1@OFFSITE-2022-06-22_11-51` on the target system and run replication again..
I ran the zfs destroy command it suggested and tried again, but it failed again with basically the same message.
Anyone know what the issue is here?
Thanks.
Are you running recursive snapshot jobs on the remote side? if you add snapshots to the replica/remote side, it's always going to bork your syncs.
seanm
I never create snapshots on the remote side. The disk sits in a drawer, once a month I plug in into the NAS, import the pool, start the replication task, then unmount the pool, and disconnect the drive. The procedure has worked for a year or more, but this time I got those errors.
Maybe if I delete the last snapshots created by the replication procedure I'd be able to start it again?
seanm
Well, I deleted the snapshots on the destination and ran replication again, then it succeeded. Phew.
