Replication failed: cannot receive resume stream: dataset is busy
KenwoodFox
I'm new to replication tasks, so I could be doing something simple wrong.
I have a large collection of old small disks I want to use as archive data, basically updating the huge pool once or twice a week, while on the same system they are not in the same box as the rest of my FreeNAS hardware, and since at the moment I don't have tape backup I feel safer with my data being stored on so many drives at once.
Anyway I attempted to replicate a collection of datasets over from my main pools, to a dataset within my archive pool, the process was slow for the most part but went well with a few datasets running for a few hours, however, I encountered a problem on one dataset that errored out the task, I am attaching the logfile from the error. Thank you.
  • 14452.log.txt
KenwoodFox
I tried replicating another dataset and got a different error about no snapshots existing, maybe replication has an issue with existing snapshots?
I tried a recursive backup on all of the datasets on my machine and re-ran the replication task but no luck. Im attaching the logfile for that.
  • 14858.log.txt
KenwoodFox
If i look in the Periodic snapshot tasks window, i see pending on some datasets when I try to push them to a corrosponding dataset in the archive pool.
When my replication task runs, and no snapshot exists, it creates one right?
Im not sure if this is my problem, its said pending for a long time now, but could this have something to do with it?
