jafin
- May 30, 2011
I have a nas running SCALE 23.10.1 cobia
I replaced 2 4TB disks with 2x 8TB drives.
The smallest drive in the array is now 6TB. (these will be replaced with 8TB once budget allows)
Autoexpand is enabled on the pool. After the resilver completed I expected the pool to expand to 6T capacity per drive. It did not, stayed at 3.6T
The closest related issue I can see is this (vdev mirror not expanding)
www.truenas.com
a55e4fd3-41f5-4557-853b-2c07724d3ad8 and 06e895bd-c236-4786-8bd9-70ac185b85f1 are the replacement 8TB drives, still showing at 3.64T
Looking at the above, there appears to be no swap partition on the replaced disks.
To my knowledge, I replaced and resilvered all drives via the GUI. The system is an update from truenas core.
I'm uncertain why some of the drives are UUID and others SDX labels.
I am uncertain why the replaced drives do not have swap partitions. (is this a bug?)
Any clues what my next steps are to fix the expand?
Should swap partitions have been created when replaced? (I understand swap was a way to accommodate small differences in similar sized drives, which seems useful)
The forum suggested export/import each drive? Doing this from CLI will this upset truenas?
I have done expands before in core without incident.
troubleshooting mirror vdev won't expand
I appear to have a similar situation as @ https://www.truenas.com/community/threads/replaced-mirror-with-larger-drives-but-cant-expand-pool.112702/ but that thread ended with inconclusively. I have a pool, tank1. It is 6 disks, 3x 2-wide mirrors. originally, it was 6x 8tb drives. I replaced...
# zpool get autoexpand NAME PROPERTY VALUE SOURCE boot-pool autoexpand off default tank1 autoexpand on local
# zpool list -v
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
boot-pool 95G 4.70G 90.3G - - 0% 4% 1.00x ONLINE -
sde3 95.3G 4.70G 90.3G - - 0% 4.94% - ONLINE
tank1 21.8T 19.9T 1.82T - - 20% 91% 1.00x ONLINE /mnt
raidz2-0 21.8T 19.9T 1.82T - - 20% 91.7% - ONLINE
a55e4fd3-41f5-4557-853b-2c07724d3ad8 3.64T - - - - - - - ONLINE
sdf2 7.28T - - - - - - - ONLINE
sdg2 5.46T - - - - - - - ONLINE
sda2 5.46T - - - - - - - ONLINE
sdc2 7.28T - - - - - - - ONLINE
06e895bd-c236-4786-8bd9-70ac185b85f1 3.64T - - - - - - - ONLINE
# lsblk -o name,partuuid,fstype,size NAME PARTUUID FSTYPE SIZE sda 5.5T ├─sda1 fe7b125c-f956-11ed-ab1b-3497f600e007 2G └─sda2 fe8fb054-f956-11ed-ab1b-3497f600e007 zfs_member 5.5T sdb 7.3T └─sdb1 a55e4fd3-41f5-4557-853b-2c07724d3ad8 zfs_member 3.6T sdc 7.3T ├─sdc1 c3afa5f9-9171-11ee-9c2b-3460f94eb9a8 2G └─sdc2 c3c6b633-9171-11ee-9c2b-3460f94eb9a8 zfs_member 7.3T sdd 7.3T └─sdd1 06e895bd-c236-4786-8bd9-70ac185b85f1 zfs_member 3.6T sde 111.8G ├─sde1 e3eea168-2e4c-4294-b4f8-730e228c4147 1M ├─sde2 aa69105b-7aa4-48f4-ab0a-f09dc760cc7c vfat 512M ├─sde3 2b96e399-88fa-4498-8d13-219b64ddb5b3 zfs_member 95.3G └─sde4 2fc39878-08c7-4021-9289-2595ed6bbc59 16G └─sde4 swap 16G sdf 7.3T ├─sdf1 0782ce1e-b1c9-11ee-a75b-3460f94eb9a8 2G └─sdf2 0796cfbd-b1c9-11ee-a75b-3460f94eb9a8 zfs_member 7.3T sdg 5.5T ├─sdg1 758f0d8f-fa84-11ed-afbe-3497f600e007 2G └─sdg2 75a2b9a5-fa84-11ed-afbe-3497f600e007 zfs_member 5.5T
