My build is:
The hardware itself runs excellent and very stable.
I first uses Ubuntu 14.04 LTS with ZoL. But ZoL on the new 3.13 kernel is crap,
because it cause the kernel hungs, if I write to the zpools.
So I installed FreeNAS-9.2.1.5-RELEASE-x64 and created the zpool new.
I use a proxy jail (debian with ziproxy, privoxy, dansguardian) and a plex jail.
My pool configuration is
With the command "zdb -C share" get
Whats alerts me is the message after the zdb:
"space map refcount mismatch: expected 48 != actual 33"
(With "zdb -C system" I get the message "space map refcount mismatch: expected 26 != actual 24
Is the space map ref count mismatch a serious error? What can I do to solve it?
Additionally, I observed that the system uses 28 Watt, if idle and hdds in standby. Under Ubuntu 14.04 it uses only 18 Watt.
I already tuned:
Is there some tuning for additional power management in FreeNAS/FreeBSD?
Mainbord with CPU: Supermicro A1SAM-C2550F
Memory: 16 GB Kingston ECC (1,35V)
Harddrives: 5x WD Red 3TB
SSD: Samsung 840 Pro (for jails)
PSU: Seasonic G-Series 360Watt
Case: Fractal-Design DEFINE R4
pool: share state: ONLINE scan: scrub repaired 0 in 4h43m with 0 errors on Mon May 12 16:46:39 2014 config: NAME STATE READ WRITE CKSUM share ONLINE 0 0 0 raidz2-0 ONLINE 0 0 0 gptid/4a94ecc5-d748-11e3-8ade-0cc47a04b680 ONLINE 0 0 0 gptid/4afcc0cf-d748-11e3-8ade-0cc47a04b680 ONLINE 0 0 0 gptid/4b6cfb52-d748-11e3-8ade-0cc47a04b680 ONLINE 0 0 0 gptid/4bd53893-d748-11e3-8ade-0cc47a04b680 ONLINE 0 0 0 gptid/4c3d819a-d748-11e3-8ade-0cc47a04b680 ONLINE 0 0 0 errors: No known data errors pool: system state: ONLINE scan: scrub repaired 0 in 0h0m with 0 errors on Wed May 14 08:20:03 2014 config: NAME STATE READ WRITE CKSUM system ONLINE 0 0 0 gptid/c2efca47-d82c-11e3-8bd5-0cc47a04b680 ONLINE 0 0 0 errors: No known data errors
MOS Configuration: version: 5000 name: 'share' state: 0 txg: 16131 pool_guid: 1981500429679314236 hostid: 3142734730 hostname: '' vdev_children: 1 vdev_tree: type: 'root' id: 0 guid: 1981500429679314236 children[0]: type: 'raidz' id: 0 guid: 145295719929335913 nparity: 2 metaslab_array: 35 metaslab_shift: 37 ashift: 12 asize: 14992202792960 is_log: 0 create_txg: 4 children[0]: type: 'disk' id: 0 guid: 15031826407315855706 path: '/dev/gptid/4a94ecc5-d748-11e3-8ade-0cc47a04b680' whole_disk: 1 create_txg: 4 children[1]: type: 'disk' id: 1 guid: 7494143635279517186 path: '/dev/gptid/4afcc0cf-d748-11e3-8ade-0cc47a04b680' whole_disk: 1 create_txg: 4 children[2]: type: 'disk' id: 2 guid: 12806404261779409058 path: '/dev/gptid/4b6cfb52-d748-11e3-8ade-0cc47a04b680' whole_disk: 1 create_txg: 4 children[3]: type: 'disk' id: 3 guid: 11506242951164426092 path: '/dev/gptid/4bd53893-d748-11e3-8ade-0cc47a04b680' whole_disk: 1 create_txg: 4 children[4]: type: 'disk' id: 4 guid: 3571886597765505926 path: '/dev/gptid/4c3d819a-d748-11e3-8ade-0cc47a04b680' whole_disk: 1 create_txg: 4 features_for_read: com.delphix:hole_birth space map refcount mismatch: expected 48 != actual 33
I already tuned:
- powerd on
- sysctl hw.acpi.cpu.cx_lowest=Cmax
- disable virtualisation in the bios
- enable aggressive sata power managent in the bios
