I updated on the 2nd of Feb and thought everything was fine. This morning I get an email that my main pool is degraded. So after investigating I see that there are 24 chksum errors on the pool and both drives in the mirror show 48. I had to get this from the command line as the GUI is not showing the errors. It shows Feb 2 as the last scrub with 0 errors. It does show the degraded status on the mirror, but nothing else useful.
So then I go to look at my periodic snapshots and it shows no snapshots have happened since the 2nd. Also my replication to my backup pool has also not happened presumably since it's based on the periodic snapshots.
I think my errors on the main pool are not a problem yet since it only listed an rrd file as possibly damaged. However, I am not sure what to do at this stage.
There doesn't appear to be a way to deal with the degraded pool in the GUI. IS it safe to just clear the pool in the command line and scrub it again?
Also any ideas what to do about the snapshots not running? Should I just recreate things. I would be inclined to go back to 11.2U7, but I already upgraded the pools so I think that's not an option?
