Problem with CIFS homes
BlazeStar
Using 9.2.1.8
Users have homes under
/mnt/data/homes/userX
Home directories are configured adequately in each user account
Home directories' permissions are set to 700
Owners of the directories are the right user
The CIFS service is configured as follow :
Enable home directories: CHECKED
Enable home directories browsing: UNCHECKED
Home directories: /mnt/data/homes
On a Windows computer, when I connect to FreeNAS I see a folder called "userX" which is the name of the user.
When I double click on it, it just gives me an "Network error" message saying Windows cannot access the folder because I do not have the permission to access it.
In the console it just reads:
Nov 14 18:07:55 NAS winbindd[3103]: [2014/11/14 18:07:55.799750,  0] ../source3/winbindd/winbindd_samr.c:769(sam_rids_to_names)
Nov 14 18:07:55 NAS winbindd[3103]:   sam_rids_to_names: possible deadlock - trying to lookup SID S-1-5-21-1412670398-1815254836-3854788144
But I seem to be getting this message every single time a share is connected, and it works anyway (except for homes)
I can't find anywhere in the logs anything related to this...
Please help :)
anodos
Sambassador
Using 9.2.1.8
Please help :)
Post your smb4.conf file. /usr/local/etc/smb4.conf
SweetAndLow
Sweet'NASty
umm.. turn on home directory browsing would be my first step.
BlazeStar
Here goes :
[global]
    server max protocol = SMB3
    interfaces = 127.0.0.1 10.0.3.20 10.99.99.20
    bind interfaces only = yes
    encrypt passwords = yes
    dns proxy = no
    strict locking = no
    oplocks = yes
    deadtime = 15
    max log size = 51200
    max open files = 11070
    load printers = no
    printing = bsd
    printcap name = /dev/null
    disable spoolss = yes
    getwd cache = yes
    guest account = nobody
    map to guest = Bad User
    obey pam restrictions = Yes
    directory name cache size = 0
    kernel change notify = no
    server string = NAS
    ea support = yes
    store dos attributes = yes
    hostname lookups = yes
    time server = yes
    acl allow execute always = true
    local master = yes
    idmap config *:backend = tdb
    idmap config *:range = 90000000-100000000
    server role = standalone
    netbios name = NAS
    workgroup = NAS
    security = user
    pid directory = /var/run/samba
    smb passwd file = /var/etc/private/smbpasswd
    private dir = /var/etc/private
    create mask = 0666
    directory mask = 0777
    client ntlmv2 auth = yes
    dos charset = CP437
    unix charset = UTF-8
    log level = 1
[homes]
comment = Home Directories
valid users = %U
writable = yes
browseable = no
path = /mnt/Data/Shares/Employes/%U
This option is for all users to be able to browse all directories, which I don't want to.
anodos
Sambassador
Here goes :
[global]
    dns proxy = no
    strict locking = no
    oplocks = yes
    deadtime = 15
    load printers = no
    printing = bsd
    getwd cache = yes
    server string = NAS
    ea support = yes
    time server = yes
    local master = yes
    netbios name = NAS
    workgroup = NAS
    security = user
    create mask = 0666
    dos charset = CP437
    log level = 1
[homes]
valid users = %U
writable = yes
browseable = no
The "browseable" parameter only makes the share visible in "network neighborhood". It does not grant read privileges.
I believe there is a typo in the path for you homes share (which may account for your write problems). If not, post output of "getfacl /mnt/Data/Shares/Employes"
Also, there is an bug/oversight in how 9.2.1.8 generates [homes] shares in the smb4.conf file, that is fixed in 9.3. In short, it doesn't generate a full share definition. You need to add the following as auxiliary parameters for your [homes] share:
veto files = /.snap/.windows/.zfs/
vfs objects = zfsacl streams_xattr aio_pthread
hide dot files = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = yes
zfsacl:acesort = dontcare
BlazeStar
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = yes
I just did, then rebooted FreeNAS.
No change: still can't access
But then I went into the FreeNAS GUI to change the permissions of the dataset "Employes" to Windows permission type, then went into console to change them back to 700 and owner = name of the share.
And now it works !
For the reccord:
# file: /mnt/Data/Shares/Employes
# owner: nobody
# group: GoupAll
            owner@:rwxpDdaARWcCos:fd----:allow
            group@:rwxpDdaARWcCos:fd----:allow
         everyone@:r-x---a-R-c---:fd----:allow
GroupAll is the group I created to put ALL users...
depasseg
FreeNAS Replicant
Did you notice your group name appears to be missing an "r"? GoupAll
BlazeStar
yup actually it's everywhere like that :S
I was worried about changing it now that everything is set up.
