Hi all
Need some help please. How do i enable powerd now and also how do i also enable the c states power saving? My cpu supports C3 according to the output but the documentation isn't clear from what i can see. Id also like to be able to throttle the cpu back when its idle to save every watt i can. I saw a post about doing a tunable for adaptive power but cant work out how to enable it.
Many thanks
the configuration database and will be reset on reboot.
root@truenas[~]# sysctl -a | grep cx_
hw.acpi.cpu.cx_lowest: C8
dev.cpu.15.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.15.cx_usage_counters: 60697 755735 41798968
dev.cpu.15.cx_usage: 0.14% 1.77% 98.08% last 83162us
dev.cpu.15.cx_lowest: C8
dev.cpu.15.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.14.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.14.cx_usage_counters: 56580 730214 41630144
dev.cpu.14.cx_usage: 0.13% 1.72% 98.14% last 25747us
dev.cpu.14.cx_lowest: C8
dev.cpu.14.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.13.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.13.cx_usage_counters: 65692 740520 40630147
dev.cpu.13.cx_usage: 0.15% 1.78% 98.05% last 46628us
dev.cpu.13.cx_lowest: C8
dev.cpu.13.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.12.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.12.cx_usage_counters: 54824 726562 40916963
dev.cpu.12.cx_usage: 0.13% 1.74% 98.12% last 29447us
dev.cpu.12.cx_lowest: C8
dev.cpu.12.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.11.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.11.cx_usage_counters: 163418 891401 40578063
dev.cpu.11.cx_usage: 0.39% 2.14% 97.46% last 88875us
dev.cpu.11.cx_lowest: C8
dev.cpu.11.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.10.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.10.cx_usage_counters: 528333 3238433 57794797
dev.cpu.10.cx_usage: 0.85% 5.26% 93.88% last 43147us
dev.cpu.10.cx_lowest: C8
dev.cpu.10.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.9.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.9.cx_usage_counters: 56787 735186 39765631
dev.cpu.9.cx_usage: 0.14% 1.81% 98.04% last 678us
dev.cpu.9.cx_lowest: C8
dev.cpu.9.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.8.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.8.cx_usage_counters: 60330 721968 38032598
dev.cpu.8.cx_usage: 0.15% 1.86% 97.98% last 30us
dev.cpu.8.cx_lowest: C8
dev.cpu.8.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.7.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.7.cx_usage_counters: 2482480 3462630 48805238
dev.cpu.7.cx_usage: 4.53% 6.32% 89.14% last 59us
dev.cpu.7.cx_lowest: C8
dev.cpu.7.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.6.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.6.cx_usage_counters: 51080 704700 40020068
dev.cpu.6.cx_usage: 0.12% 1.72% 98.14% last 432us
dev.cpu.6.cx_lowest: C8
dev.cpu.6.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.5.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.5.cx_usage_counters: 50452 700986 40766471
dev.cpu.5.cx_usage: 0.12% 1.68% 98.19% last 266us
dev.cpu.5.cx_lowest: C8
dev.cpu.5.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.4.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.4.cx_usage_counters: 48488 692795 39390406
dev.cpu.4.cx_usage: 0.12% 1.72% 98.15% last 7126us
dev.cpu.4.cx_lowest: C8
dev.cpu.4.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.3.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.3.cx_usage_counters: 49928 709424 39275800
dev.cpu.3.cx_usage: 0.12% 1.77% 98.10% last 9217us
dev.cpu.3.cx_lowest: C8
dev.cpu.3.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.2.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.2.cx_usage_counters: 54611 707313 47076283
dev.cpu.2.cx_usage: 0.11% 1.47% 98.40% last 237us
dev.cpu.2.cx_lowest: C8
dev.cpu.2.cx_supported: C1/1/1 C2/2/15 C3/2/41
dev.cpu.1.cx_method: C1/mwait/hwc C2/mwait/hwc/bma C3/mwait/hwc/bma
dev.cpu.1.cx_usage_counters: 49270 692739 38584173
dev.cpu.1.cx_usage: 0.12% 1.76% 98.11% last 5731us
dev.cpu.1.cx_lowest: C8
Many thanks
