pool size, autoexpand and what am I missing?
Xcapee
I have a 4 drive RAIDZ zpool, which now has 4x3TB WD Green drives. It started with 2x3TB and 2x2TB drives because that was what I had on hand. I have since replaced the 2x2TB drives with 3TB drives (resilvering with each drive). autoexpand was true prior to the replacements.
Each WD Green Drive reports 3.00TB
bosnas# smartctl -i /dev/ada3 | grep Capacity
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
bosnas# smartctl -i /dev/ada2 | grep Capacity
bosnas# smartctl -i /dev/ada1 | grep Capacity
bosnas# smartctl -i /dev/ada0 | grep Capacity
So I would expect the size of the zpool to be 9TB or 8.18TiB but
bosnas# zpool list
NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT
tank 7.25T 4.17T 3.08T 57% 1.00x ONLINE /mnt
I am assuming the size reported is in TiB, but that still leaves about 1TB that appears to be AWOL.
7.25 TiB is pretty close to 8TB so I am guessing zfs is still looking at the vdev as being built on 2TB drives. So assuming it was the autoexpand that failed, I exported the drives and imported them as per Enabling ZFS Pool Expansion After Drive Replacement. No change.
What am I missing?
Dusan
Try to run "zpool online -e tank <device>" for every component of the pool (the devices you see in zpool status).
Xcapee
Thank you. That fixed it. The man page is very sparse on zpool online. What does the -e flag do? Expand?
bosnas# zpool online -e tank ada0
bosnas# zpool online -e tank ada1
bosnas# zpool online -e tank ada2
bosnas# zpool online -e tank ada3
bosnas# zpool list
tank 10.9T 4.17T 6.70T 38% 1.00x ONLINE /mnt
Xcapee
Ha ha - thanks. I just realised I've been reading the FreeBSD Release 8.1 man pages (which as I say, had very sparse info on "online").
So, any theories why autoexpand may not have worked?
Dusan
Is the autoexpansion enabled? What does "zpool get autoexpand tank" say?
Xcapee
bosnas# zpool get autoexpand tank
NAME PROPERTY VALUE SOURCE
tank autoexpand on local
Xcapee
I had set it from the command line, prior to any of the drives being replaced (I think).
Dusan
Sorry, no idea at the moment. I would have to check the code.
Xcapee
I am guessing I might have turned autoexpand on after I replaced one of the failed 3TB drives. Even though it wouldn't have expanded at this point, since I wasn't at 4x3TB, it may have missed the opportunity since each drive needed to be told to expand with the online -e. It may have been that only one device was blocking the expansion as a whole.
Thanks again for your help :)
