Plugins not starting after setting up jails storage
andrenel212
Im new to FreeNAs so go easy on me. I installed plugins, created storage for Jails but now my plugin services wont start. I get the following errors:
Jailer
Not strong, but bad
Did you change the permissions on your jails dataset?
andrenel212
No I dont know how SB
Vito Reiter
Wise in the Ways of Science
Volumes > Click on the jails storage > at the bottom left one of those buttons is for permissions. Go ahead and click it, and set it up as applicable to your setup.
andrenel212
I checked the permissions and all 777, when i update permission i get the following errors in system console:
May 2 16:23:01 Mordor manage.py: [freeadmin.navtree:631] An error occurred while unserializing from http://192.168.0.2/plugins/plexmediaserver/3/_s/treemenu: No JSON object could be decoded
May 2 16:23:01 Mordor manage.py: [freeadmin.navtree:631] An error occurred while unserializing from http://192.168.0.2/plugins/transmission/4/_s/treemenu: No JSON object could be decoded
May 2 16:23:41 Mordor manage.py: [plugins.utils:91] Couldn't retrieve http://192.168.0.2/plugins/plexmediaserver/3/_s/status: No JSON object could be decoded
May 2 16:23:41 Mordor manage.py: [plugins.utils:91] Couldn't retrieve http://192.168.0.2/plugins/transmission/4/_s/status: No JSON object could be decoded
May 2 16:24:50 Mordor manage.py: [freeadmin.navtree:631] An error occurred while unserializing from http://192.168.0.2/plugins/plexmediaserver/3/_s/treemenu: No JSON object could be decoded
May 2 16:24:50 Mordor manage.py: [freeadmin.navtree:631] An error occurred while unserializing from http://192.168.0.2/plugins/transmission/4/_s/treemenu: No JSON object could be decoded
May 2 16:25:03 Mordor manage.py: [freeadmin.navtree:631] An error occurred while unserializing from http://192.168.0.2/plugins/plexmediaserver/3/_s/treemenu: No JSON object could be decoded
May 2 16:25:03 Mordor manage.py: [freeadmin.navtree:631] An error occurred while unserializing from http://192.168.0.2/plugins/transmission/4/_s/treemenu: No JSON object could be decoded
May 2 16:25:12 Mordor manage.py: [plugins.utils:91] Couldn't retrieve http://192.168.0.2/plugins/plexmediaserver/3/_s/status: No JSON object could be decoded
May 2 16:25:13 Mordor manage.py: [plugins.utils:91] Couldn't retrieve http://192.168.0.2/plugins/transmission/4/_s/status: No JSON object could be decoded
May 2 16:26:42 Mordor manage.py: [freeadmin.navtree:631] An error occurred while unserializing from http://192.168.0.2/plugins/plexmediaserver/3/_s/treemenu: No JSON object could be decoded
May 2 16:26:42 Mordor manage.py: [freeadmin.navtree:631] An error occurred while unserializing from http://192.168.0.2/plugins/transmission/4/_s/treemenu: No JSON object could be decoded
Vito Reiter
Before we continue can you post build version and full hardware specs?
andrenel212
I am running a virtual machine through vmware on my imac temporarily once i can get this working i will purchase a pc.
Vito Reiter
Running FreeNAS in a VM with less than the recommended hardware specs is not a very good testing environment. Just double check your network settings and make sure they're setup correctly as well since it's not a hard-line and probably either VirtIO and/or bridged.
andrenel212
I get the same problems when running a vm off my MacBook with 8gb ram. Don't won't to fork out the cash if it doesmt work but guess will have to bite the bullet
Vito Reiter
You can make a FreeNAS boot USB and test it with a real machine temporarily. I'm not saying go out and buy a whole system, just saying FreeNAS isn't built to be run in a VM. Also, if you got the same error on two different setups, maybe research how you're setting it up and if it's the correct way per what you're trying to do.
