Persistent epair interface in jail?
digilink
I'm running a FreeNAS Mini appliance and have both network cards on different networks. I created a jail to host DNS and DHCP for the network located on igb0.
The problem I seem to have encountered is that the interface changes on a reboot and kills my dhcpd daemon (I'm using ISC-dhcpd) due to it listening on a specific interface defined in /etc/rc.conf:
dhcpd_enable="YES"
dhcpd_flags="-q"
dhcpd_conf="/usr/local/etc/dhcpd.conf"
dhcpd_ifaces="epair0b"
dhcpd_withumask="022"
Is there a way to make this interface persistent across reboots?
Nick2253
What interface is changing on reboots? The jail interface? And what about it is changing? Mac address? IP address?
digilink
Looks to be the jail interface itself. For example, when I first built out the jail, the interface assigned was epair1b (if I remember correctly, it was different than what it is now anyhow). I rebooted the FreeNAS server and that's when I discovered it had changed to the current interface of epair0b.
This is the output of my ifconfig (from the jail):
sbrown@delorean:~ % ifconfig
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:7a:f4:00:0e:0b
        inet 10.0.10.25 netmask 0xffffff00 broadcast 10.0.10.255
        status: active
Nick2253
Now, that is weird. If you reboot again, does it change again? Or does it only change sporadically?
digilink
Just rebooted again, it's still epair0b, so maybe something was just flakey. I was mainly concerned if this was a natural behavior or not, and was going to set it accordingly to compensate if so.
