niclas197
- Jul 29, 2011
Hey,
I'm having issues with poor performance on my raidZ with 4k drives.
my specs are:
I only get around 30 Megabyte/s on the RaidZ
I created a new pool using the WebGUI and I've checked the 4k Box.
I use this harddisks:
Every data transfer (doesn't matter if via CIFS or AFP) looks like this in reporting:
The transfer rate goes to 40 MB/s (i've double checked in the Mac os X activity monitor) and then falls to a few KB/s for a few seconds and then goes up again.
I don't know if it's my drive setup or something else but it's really annoying since even these "green" drives should get around 80 MB/s local
my specs are:
Hostname: freenas.localdomain OS Version: FreeBSD 8.2-RELEASE-p2 Platform: AMD Athlon(tm) II Neo N36L Dual-Core Processor Memory: 2928MB System Time: Fri Jul 29 10:39:30 CEST 2011 Uptime: 10:39AM up 36 mins, 1 user Load Average: 0.02, 0.08, 0.12 FreeNAS Build: FreeNAS-8.0.1-BETA4-amd64
freenas# dd if=/dev/zero of=ddtest bs=1024k count=2000 2000+0 records in 2000+0 records out 2097152000 bytes transferred in 70.356555 secs (29807486 bytes/sec)
ada0: <WDC WD20EARS-00MVWB0 51.0AB51> ATA-8 SATA 2.x device ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada1: <WDC WD20EARS-22MVWB0 51.0AB51> ATA-8 SATA 2.x device ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada2: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada2: Command Queueing enabled ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada3: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada3: Command Queueing enabled ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada0: <WDC WD20EARS-00MVWB0 51.0AB51> ATA-8 SATA 2.x device ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada1: <WDC WD20EARS-22MVWB0 51.0AB51> ATA-8 SATA 2.x device ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada2: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada2: Command Queueing enabled ada2: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada3: <ST2000DL003-9VT166 CC32> ATA-8 SATA 3.x device ada3: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) ada3: Command Queueing enabled ada3: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C)
