PCI Passthrough
Eleven
I'm currently attempting to pass through a PCIe USB controller to a VM in TrueNAS core with the aim of attaching my printers to it allowing me to create a print server that I previously had on an M72 mini pc.
This is the device in question:
This is my Tunables table within TrueNAS:
When attempting to assign it to the VM:
Nothing shows up. Any thoughts or suggestions would be apricated!
Thanks!
Patrick M. Hausen
It's vmm_load, not wmm_load ...
Momos
Resurrecting an old thread, but can you please describe how to pass the PCIe USB controller to a VM in TrueNas Core ?
I have a PCIe USB controller that i want to pass to a VM with Home Assistant OS.
Thank you !
It's pretty much right there in that first post (if you take the w to v correction into account).
The missing part at the start is that you run pciconf -lv to see the numbers at the start of that screenshot
You take the last 3 numbers from the bit at the beginning of the line and use those with slashes instead of colons between them in the pptdevs entry.
from that example,
xhci0@pci0:1:0:0:
becomes
1/0/0
