delta_alpha_november
- Sep 22, 2023
Hi, I am trying to migrate from TrueNAS core 12 to a new machine running Truenas scale bluefin which I just installed.
I have set up the new machine with a mirrord special device and a single 8TB HDD for now.
I replicated all datasets under the root level to my new machine using the UI recursively, which seemed to have worked.
Here are my replication settings:
The pool is encrypted and unlocked.
However, the root dataset behaves very strange and I can't figure out why.
It will not let me mount some of the datasets or even just make files and/or directories in the pool directly, as per below.
The pool is not mounted read-only. The datasets I'm trying to mount aren't either:
On the other hand some of the datasets I did replicate over work just fine:
I have tried changing the ACL type through the UI without luck.
I have checked that these datasets are not read-only.
I have tried exporting and reimporting the pool.
I'm pretty much out of ideas where the problem might be. The pool has been scrubbed today without any errors.
I could nuke the pool and start over but I'd really like to understand what went wrong. I think all of the affected datasets are datasets without POSIX ACLs on my old truenas core machine which have been used as SMB shares.
root@truenas[/mnt/Daten]# zfs list | grep -v boot NAME USED AVAIL REFER MOUNTPOINT Daten 4.78T 2.36T 336K /mnt/Daten Daten/Backups 916G 2.36T 184K /mnt/Daten/Backups Daten/Backups/location 916G 2.36T 244K /mnt/Daten/Backups/location Daten/Backups/location/Public 9.37G 2.36T 8.84G /mnt/Daten/Backups/location/Public Daten/Backups/location/Name3 30.2M 2.36T 240K /mnt/Daten/Backups/location/Name3 Daten/Backups/location/admin 907G 2.36T 807G /mnt/Daten/Backups/location/admin Daten/Downloads 108G 2.36T 108G /mnt/Daten/Downloads Daten/Name1SSD 151G 2.36T 151G - Daten/gemeinsam 1.11T 2.36T 893G /mnt/Daten/gemeinsam Daten/home 1.76T 2.36T 248K /mnt/Daten/home Daten/home/Name2 1.45T 2.36T 695G /mnt/Daten/home/Name2 Daten/home/Name1 314G 2.36T 206G /mnt/Daten/home/Name1 Daten/retropie 800M 2.36T 797M /mnt/Daten/retropie Daten/location 775G 2.36T 774G /mnt/Daten/location
root@truenas[/mnt/Daten]# mount | grep Daten Daten on /mnt/Daten type zfs (rw,noatime,xattr,posixacl,casesensitive) Daten/Backups on /mnt/Daten/Backups type zfs (rw,noatime,xattr,posixacl,casesensitive) Daten/Backups/location on /mnt/Daten/Backups/location type zfs (rw,noatime,xattr,posixacl,casesensitive) Daten/Backups/location/Name3 on /mnt/Daten/Backups/location/Name3 type zfs (rw,noatime,xattr,posixacl,casesensitive) Daten/Backups/location/Public on /mnt/Daten/Backups/location/Public type zfs (rw,noatime,xattr,posixacl,casesensitive) Daten/Backups/location/admin on /mnt/Daten/Backups/location/admin type zfs (rw,noatime,xattr,posixacl,casesensitive) root@truenas[/mnt/Daten]# zfs mount -a cannot mount '/mnt/Daten/Downloads': failed to create mountpoint: Operation not permitted cannot mount '/mnt/Daten/gemeinsam': failed to create mountpoint: Operation not permitted cannot mount '/mnt/Daten/retropie': failed to create mountpoint: Operation not permitted cannot mount '/mnt/Daten/home': failed to create mountpoint: Operation not permitted cannot mount '/mnt/Daten/location': failed to create mountpoint: Operation not permitted root@truenas[/mnt/Daten]# zpool status Daten pool: Daten state: ONLINE scan: scrub repaired 0B in 06:41:02 with 0 errors on Fri Sep 22 19:22:12 2023 config: NAME STATE READ WRITE CKSUM Daten ONLINE 0 0 0 e8dee78e-de34-49d2-b4e5-4abdb79a1912 ONLINE 0 0 0 special mirror-1 ONLINE 0 0 0 852f08f6-25e2-424c-87c6-42a53b75af4c ONLINE 0 0 0 a10e4cd4-31cf-4a7a-b370-202a08885446 ONLINE 0 0 0 errors: No known data errors root@truenas[/mnt/Daten]# mkdir test mkdir: cannot create directory ‘test’: Operation not permitted root@truenas[/mnt/Daten]# ll total 35 drwxr-xr-x 5 root 5 Sep 20 17:39 ./ drwxr-xr-x 3 root 3 Sep 22 12:26 ../ drwxr-xr-x 4 root 4 Sep 22 12:32 Backups/ drwxrwxrwx 2 root 2 Sep 20 14:40 OldDaten/ drwxr-xr-x 2 root 2 Sep 22 12:43 ix-applications/
root@truenas[/mnt/Daten]# zfs get readonly Daten/gemeinsam NAME PROPERTY VALUE SOURCE Daten/gemeinsam readonly off inherited from Daten
root@truenas[/mnt/Daten/Backups]# mkdir test root@truenas[/mnt/Daten/Backups]# ls WindowsBackups test location root@truenas[/mnt/Daten/Backups]# cd test root@truenas[/mnt/Daten/Backups/test]# ls root@truenas[/mnt/Daten/Backups/test]# touch file root@truenas[/mnt/Daten/Backups/test]# ll total 18 drwxr-xr-x 2 root 3 Sep 22 23:05 ./ drwxr-xr-x 5 root 5 Sep 22 23:05 ../ -rw-r--r-- 1 root 0 Sep 22 23:05 file root@truenas[/mnt/Daten/Backups/test]# rm file root@truenas[/mnt/Daten/Backups/test]# cd .. root@truenas[/mnt/Daten/Backups]# rmdir test
