itskando
- Apr 30, 2018
I have successfully gotten openVPN to connect to my server.
When connected on a LAN without the use of openVPN,
I am able to connect to the SFTP using the Transmit app client via
When connected via openVPN in a remote location, however,
I am unable to connect to any FTP using the mac OS client or the Transmit app client, even though
I am able to connect to ssh (via terminal) and to the freeNAS GUI (via web browser).
When connected via openVPN in a remote location, I have:
• verified that FTP is enabled in the freeNAS GUI.
• tried connecting via:
• tried connecting via FTP and SFTP.
• tried to connect via a user in the FTP group and (briefly) via root user.
• tried setting Services --> FTP --> Masquerade Address to hostname
Service --> FTP --> Configure:
In all cases, the server is not found. Any suggestions?
I have found similar issues in the following threads,
which appear to discuss port forwarding as the solution, but
are old, locked, vague, and do not specify whether this solution bypasses openVPN:
www.ixsystems.com
www.ixsystems.com
<servername>.local
.When connected via openVPN in a remote location, however,
<servername>.local
<servername>.nas.<domainName>.com
<domainIPaddress>
Port : 21 Clients : 5 Connections : 10 Login Attempts : 1 Timeout : 600 Allow root login : Yes [Temporarily] Allow anonymous login : No Allow local user login : Yes Display Login : <blank> Allow Transfer Resumption : Yes Always Chroot : Yes Perform Reverse DNS Lookups: No Masquerade Address : <blank> Certificate : <blank> TLS No Certificate Required: No
Finally Fixed FTP port forwarding!!
Hello, I'm so excited that I finally fixed this (though it may seem minor) I had to share this in case anyone else has the same problem. This problem may not be SPECIFIC to Freenas, and really it's not even Freenas' problem. I have a Netgear router connected to Comcast Cable. I setup Freenas and...
How to connect freenas ftp to outside world
Hi, even after I follow the step in this post, i can´t access to my freenas via ftp o sftp from outside world. I have ports 21 and 22 forwarded to the local address of my free nas but whenever i tried to connect via filezilla or internet explorer i have a Timeout error. This doesn´t happen in...
