SOLVED OpenVPN failed to start
white_noise
Can anyone assist with my issue, i'm stumped and its likely someone very simple.
This is inside of a transmission jail and i getting the following error when i try to start up OpenVPN but from what i can see the file is present in the correct directory.
[root@transmission_1 /usr/local/etc/openvpn]# ls
keys openvpn.conf
[root@transmission_1 /usr/local/etc/openvpn]# cd keys
[root@transmission_1 /usr/local/etc/openvpn/keys]# ls
ca.crt
[root@transmission_1 /usr/local/etc/openvpn/keys]# /usr/local/etc/rc.d/openvpn start
Starting openvpn.
/usr/local/etc/rc.d/openvpn: WARNING: failed to start openvpn
output from messages
Feb 22 14:57:05 transmission_1 openvpn[47954]: Options error: --ca fails with 'ca.crt': No such file or directory
Feb 22 14:57:05 transmission_1 openvpn[47954]: Options error: Please correct these errors.
Feb 22 14:57:05 transmission_1 openvpn[47954]: Use --help for more information.
Feb 22 14:57:05 transmission_1 root: /usr/local/etc/rc.d/openvpn: WARNING: failed to start openvpn
Check first if the path in the OpenVPN config for the certificate(s) is /usr/local/etc/openvpn/keys/(ca.crt)
(mine are in the OpenVPN folder, not in keys for example)
Also check that the OpenVPN user has access rights to the crt file
white_noise
Thank you! you are correct the keys did not need to be in a folder keys.
djrkd
im trying to set this up for the first time, can someone help me and tell me where to get or create the user.crt user.key and ta.key ? I have the ca.crt from PIA (my VPN provider)
Thanks!
You only need the ca.crt file (and config file of course)
If you read a little more (as in: the whole thread), you'll see that some mention they only have that one file. I only have one also. Just follow the steps. Make sure you select the option to enable password saving for auth-user-pass when you install OpenVPN and later that the path to the .crt file is correct in your config file. That are the most important additions to the initial post there.
Supa
I'm having the same problem actually.
Whenever I change my server to a 2 word one.. I get this error: Options error: --ca fails with '/ usr/local/etc/openvpn//usr/local/etc/openvpn/ca.crt': No such file or directory Options error: --crl-verify fails with '/usr/local/etc/openvpn//usr/local/etc/openvpn/crl.pem': No such file or directory
while if I keep it on like Switzerland/Mexico... any server with 1 word it works just fine. Any ideas?
Filenames with spaces should be addressed like this "/path/file name.ext" or this '/path/file name.ext'
Supa
I'm pretty sure i've tried it both ways...
openvpn_configfile="/usr/local/etc/openvpn/US_California.ovpn"
and
openvpn_configfile="/usr/local/etc/openvpn/US California.ovpn"
When i put a space it says:
/usr/local/etc/rc.d/openvpn: WARNING: /usr/local/etc/openvpn/US is not readable.
/usr/local/etc/rc.d/openvpn: WARNING: failed precmd routine for openvpn
When I put an underscore openvpn won't even start...
Dumb question maybe, but did you also change the actual filename accordingly?
