In the little window at the bottom of the gui interface, I see the below errors. My smb share works just fine as far as I know. I don't like seeing errors, no matter if it affects me or not. I have looked at other threads that had this message, but non of them fixed it for me. wbinfo -u and wbinfo -g works just fine.
Any ideas?
Any ideas?
Feb 3 08:56:21 G1PPFreeNas01 smbd: in openpam_check_error_code(): pam_sm_acct_mgmt(): unexpected return value 12 Feb 3 08:56:28 G1PPFreeNas01 smbd: in openpam_check_error_code(): pam_sm_acct_mgmt(): unexpected return value 12 Feb 3 08:58:35 G1PPFreeNas01 smbd: in openpam_check_error_code(): pam_sm_setcred(): unexpected return value 12 Feb 3 08:58:35 G1PPFreeNas01 smbd: in openpam_check_error_code(): pam_sm_setcred(): unexpected return value 12
[root@G1PPFreeNas01] /var/log/samba4# testparm
Load smb config files from /usr/local/etc/smb4.conf
Processing section "[Share]"
Loaded services file OK.
Server role: ROLE_DOMAIN_MEMBER
[global]
dos charset = CP437
realm = FIREMOUNTAIN.LOCAL
workgroup = FIREMOUNTAIN
domain master = No
lm announce = Yes
local master = No
preferred master = No
client ldap sasl wrapping = plain
logging = file
max log size = 51200
cache directory = /var/tmp/.cache/.samba
kernel change notify = No
pid directory = /var/run/samba
disable spoolss = Yes
load printers = No
printcap name = /dev/null
server min protocol = SMB2
allow trusted domains = No
map to guest = Bad User
obey pam restrictions = Yes
security = ADS
server role = member server
deadtime = 15
hostname lookups = Yes
max open files = 1883288
template homedir = /home/%U
template shell = /bin/sh
winbind cache time = 7200
winbind enum groups = Yes
winbind enum users = Yes
winbind offline logon = Yes
winbind refresh tickets = Yes
winbind use default domain = Yes
dns proxy = No
idmap config firemountain: range = 20000-90000000
idmap config firemountain: backend = rid
idmap config * : backend = tdb
store dos attributes = Yes
strict locking = No
directory name cache size = 0
dos filemode = Yes
acl allow execute always = Yes
ea support = Yes
create mask = 0666
directory mask = 0777
[Share]
path = /mnt/Share/Share
veto files = /.snapshot/.windows/.mac/.zfs/
read only = No
vfs objects = zfs_space zfsacl aio_pthread
zfsacl:acesort = dontcare
nfs4:chown = true
nfs4:acedup = merge
nfs4:mode = special
