npm start and keep running
I have a jail setup on my FreeNAS server, and have gotten Mellow (https://github.com/v0idp/Mellow) to run. However I am stuck on how to get it to start automatically with the jail, and keep running in the background. As of right now it only runs when I manually input "npm start" and by keeping the shell window open. Any help would be appreciated, Ive googled different options however I cant seem to get anything to actually work. Thanks!
well, at very least you could try npm start & which should allow you to close the window.
I'm having a quick look at the homebridge plugin (also an NPM package) and will see if there's a clue in there.
Looks like they have placed a file in /usr/local/bin/
Called homebridge, with these contents:
#!/usr/bin/env node
// This executable sets up the environment and runs the HomeBridge CLI.
"use strict";
process.title = "homebridge";
// Find the HomeBridge lib
const path = require("path");
const fs = require("fs");
const lib = path.join(path.dirname(fs.realpathSync(__filename)), "../lib");
// Run HomeBridge
require(lib + '/cli')();
There is also a service configured (/usr/local/etc/rc.d/pm2_root):
#!/bin/sh
# PROVIDE: pm2
# REQUIRE: LOGIN
# KEYWORD: shutdown
. /etc/rc.subr
name="pm2_root"
rcvar="pm2_root_enable"
start_cmd="pm2_start"
stop_cmd="pm2_stop"
reload_cmd="pm2_reload"
status_cmd="pm2_status"
extra_commands="reload status"
pm2()
  env PATH="$PATH:/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/sbin:/usr/local/bin:/root/bin" PM2_HOME="/root/.pm2" su -m "root" -c "/usr/local/lib/node_modules/pm2/bin/pm2 $*"
pm2_start()
  pm2 resurrect
pm2_stop()
  pm2 kill
pm2_reload()
  pm2 reload all
pm2_status()
  pm2 list
load_rc_config $name
run_rc_command "$1"
Seems that you might be able to get the same result if you did it with mellow?
That "npm start & " command is amazing! Helps to get me up and running for right now. I tried the pm2 option before, but im new to this and maybe didnt get my code right. I will see if I can get that Homebridge code to take. Thanks!
Patrick M. Hausen
The documentation for that is right here:
It might be easier to install and enable supervisord and use that to start your npm service.
pkg install py37-supervisor
sysrc supervisord_enable=YES
HTH,
Patrick
