Not found jls truenas scale
K.J
Dear all,
Do you guys have any idea how I can open jls?
Now get the message NOT FOUND JLS.
Version: TrueNAS-SCALE-22.02.4
Jailer
Not strong, but bad
What is jls?
Jailer, you of all people should know this--jls was the command to list jails, particularly in the Warden days. Completely inapplicable to SCALE, of course, which uses Linux and thus doesn't have jails. Google also tells me that that command under Linux can "list the records and entries in a file system journal"--which doesn't seem in any way relevant to anything a user ought to be doing on any flavor of TrueNAS.
K.J
Hi @danb35 @Jailer
Something started bubbling that scale doesn't work with jails, stupid!
IK used it in CORE to eventually update plex manually via that way.
danb35 is there any other way in scale to access docker apps via shell?
If they're apps you've installed through SCALE, all the ones I've used (which are all from Truecharts) have a way to get to a shell for the container:
There's probably a way to do it through the CLI, but I wouldn't know what that would be. But what are you trying to accomplish here? If you want to update Plex, update the Plex application--or do the same for any other app you're using.
Jailer
Not strong, but bad
I asked for a reason. :wink: And it still works btw.
And that is the reason I asked.
With Scale you're going to have to figure out the container way of doing things.
K.J
@danb35
At the time of core, I had a script via github to update plex in shell.
In scale I always update plex through the app itself.
Now it keeps running for minutes. Nothing happens in the end.
Thought hey, just use the github script.
Unfortunately that doesn't work anymore.
K.J
@danb35
The update from the app succeeded.
Had in: Apps - applications - settings - advanced settings the ip address was still set to 0.0.0.0.
