NFS sharing not working...
pablixrubio
Good morning,
I've been trying to enable NFS sharing in one of my pools and it's been impossible. I'm using Active Directory to access the pool. SMB sharing is working perfecty but the problem comes when i try to access the same pool from my Linux device.
I can mount the pool without any problems but i can't access to it using the Active Directory account with permissions to do it.
Something strange is that i can access from the root user of the Linux device...
I think i tryed every type of configuration but nothing works.
Any help is welcome. Thanks a lot!
Best regards,
Pablo.
Version: TrueNAS-12.0-U5.1
RAM: 16 GiB
CPUs: 4
Disks: 315 GiB
I think that "Security" field is probably important to set if you want the share to interpret the Kerberos permissions. I see you made no selection there and I don't know the default in that case.
