I have two FreeNAS boxes with 9.2.1.7. Boxes clear installed. (not upgraded)
And i cant mount this nfs from ubuntu (12.04 and 14.04), rpcbind and nfsd at server started.
When i try to mount it:
mount -t nfs 192.168.110.251:/mnt/safe1 /mnt/net
It's just hangup for long time, and after it show mount timeout.
When i do showmount -e 192.168.110.251 (my freenas box)
it hangup for long time, but give me exports list:
root@nfsclient:~# showmount -e 192.168.110.251
Export list for 192.168.110.251:
/mnt/safe1 192.168.110.0
If i from this client try mount another nfs share from test linux box, everything work fine and fast. All boxes in one subnet, all firewalls disabled. I tried to add host name to hosts file for server and client.
Help, help!!! :(
Some info from 192.168.110.251 serverside :
[root@nas2] ~# ps auxc|grep nfsd
root 7668 0.0 0.1 9900 1840 ?? Is 2:08PM 0:00.01 nfsd
root 7669 0.0 0.1 9900 1668 ?? I 2:08PM 0:00.00 nfsd
[root@nas2] ~# ps auxc | grep rpc
root 7629 0.0 0.1 14124 1996 ?? Ss 2:08PM 0:00.01 rpcbind
root 7693 0.0 0.1 274144 1896 ?? Ss 2:08PM 0:00.00 rpc.statd
root 7725 0.0 0.1 14120 1924 ?? Ss 2:08PM 0:00.00 rpc.lockd
[root@nas2] ~# cat /etc/exports
/mnt/safe1 -alldirs -network 192.168.110.0/24
[root@nas2] ~# showmount -e localhost
Exports list on localhost:
[root@nas2] ~# rpcinfo -p localhost
program vers proto port service
100000 4 tcp 111 rpcbind
100000 3 tcp 111 rpcbind
100000 2 tcp 111 rpcbind
100000 4 udp 111 rpcbind
100000 3 udp 111 rpcbind
100000 2 udp 111 rpcbind
100000 4 local 111 rpcbind
100000 3 local 111 rpcbind
100000 2 local 111 rpcbind
100005 1 udp 795 mountd
100005 3 udp 795 mountd
100005 1 tcp 795 mountd
100005 3 tcp 795 mountd
100003 2 udp 2049 nfs
100003 3 udp 2049 nfs
100003 2 tcp 2049 nfs
100003 3 tcp 2049 nfs
100024 1 udp 815 status
100024 1 tcp 815 status
100021 0 udp 958 nlockmgr
100021 0 tcp 959 nlockmgr
100021 1 udp 958 nlockmgr
100021 1 tcp 959 nlockmgr
100021 3 udp 958 nlockmgr
100021 3 tcp 959 nlockmgr
100021 4 udp 958 nlockmgr
100021 4 tcp 959 nlockmgr
Serverside TCPdums:
After run at client root@nfsclient:~# mount -t nfs 192.168.110.251:/mnt/safe1 /mnt/net/
[root@nas2] ~# tcpdump -vv host 192.168.110.248
tcpdump: listening on re0, link-type EN10MB (Ethernet), capture size 65535 bytes
14:25:04.043141 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has nfsclient tell w8.lan, length 46
14:26:56.256932 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has nas2 tell nfsclient, length 46
14:26:56.256942 ARP, Ethernet (len 6), IPv4 (len 4), Reply nas2 is-at f4:ec:38:80:cb:82 (oui Unknown), length 28
14:27:07.420471 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has nfsclient tell w8.lan, length 46
After run at client root@nfsclient:~# showmount -e 192.168.110.251
14:27:49.712755 IP (tos 0x0, ttl 64, id 43734, offset 0, flags [DF], proto UDP (17), length 84)
nfsclient.850 > nas2.sunrpc: [udp sum ok] UDP, length 56
14:27:49.712838 IP (tos 0x0, ttl 64, id 32526, offset 0, flags [none], proto UDP (17), length 56)
nas2.sunrpc > nfsclient.850: [udp sum ok] UDP, length 28
14:28:25.793118 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has nas2 tell nfsclient, length 46
14:28:25.793128 ARP, Ethernet (len 6), IPv4 (len 4), Reply nas2 is-at f4:ec:38:80:cb:82 (oui Unknown), length 28
14:28:57.856967 ARP, Ethernet (len 6), IPv4 (len 4), Request who-has nas2 tell nfsclient, length 46
14:28:57.856976 ARP, Ethernet (len 6), IPv4 (len 4), Reply nas2 is-at f4:ec:38:80:cb:82 (oui Unknown), length 28
14:29:56.977477 IP (tos 0x0, ttl 64, id 43735, offset 0, flags [DF], proto UDP (17), length 84)
14:29:56.977535 IP (tos 0x0, ttl 64, id 44841, offset 0, flags [none], proto UDP (17), length 56)
14:29:56.977835 IP (tos 0x0, ttl 64, id 43736, offset 0, flags [DF], proto UDP (17), length 104)
nfsclient.850 > nas2.951: [udp sum ok] UDP, length 76
14:29:56.978231 IP (tos 0x0, ttl 64, id 44842, offset 0, flags [none], proto UDP (17), length 104)
nas2.951 > nfsclient.850: [udp sum ok] UDP, length 76
Help, help!!! :(
Serverside TCPdums:
