Newbie Transmission help
fajoza45
Hello everyone and thank you for all the support.
I just built my first NAS using FreeNAS 9.1.1 and I was quite proud of myself till I couldn't figure out Transmission. I've been reading and searching for the last couple of days on how to get Transmission to work. I followed the Wiki and was able to install transmission which also added a Jail. I have followed this video tutorial http://www.freenas.org/about/videos.html but the mount point option does not appear. Also I attempted to get into the transmission webGui but was unable to.
Thank you in advanced for all your help.
fajoza45
Wow 80 plus views and no help. Well I was able to get transmission running. Now my issue is that I'm not able to move or delete the downloaded contents.. I'll keep reading and hopefully I get lucky since I probably wont get any help here.. For those that are stuck with my first issue follow this guide (http://lifehacker.com/turn-an-old-computer-into-a-do-anything-home-server-wit-510023147) it got it working for me.. Just scroll down to the bottom...
Good Luck..
N00b
The mount point option is a small button that appears when you select the relevant jail on the jails tab. See attached PDF.Hopefully this helps.
  • Doc1a.pdf
