I am just starting with FreeNAS and have been reading all the documentation I could find. I also have my first small test system set up with the plan to build a larger system later after I know what I'm doing.
My question is this, I have the chance to buy a Chelsio Dualport PCIe 10GBit Network Card (T520-LL-CR) quite cheap (returned merchandise) from a reputable dealer. This would be great for my next system.
Since I need to order it quickly can anyone tell me if it is compatible with FreeNAS?
I found a reference to it on the Free-BSD hardware compatibility list that with the correct settings it's compatible but the rest of what I found was not definitive or at least what I was able to understand.
Thanks in advance,
Patrick
Thanks in advance,
Patrick
