Need help with shares
Thomas.arnard
I have made a share but keep getting "You need permission to perform this action" every time I try to move a file in to the share. I have listed everything I did step by step. Right now what I am wanting is to just be about to move file in to the share and let some different see them. After I can get that, I need to get it working with AD.
1. made a vol:
Made it a Raid Z with 4 2TB hard drives.
2. Made a Dataset:
Compression Level: Inherit(lz4)
Share type: Unix
Case Sensitivity: Insensitive
Enable Atime: Inherit
ZFS Deduplication: Inherit (off)
3.Made a user:
User ID: 1001
Username Everyone
Create a new group for user: checked
Primary group: nothing
Create Home Dir In: /mnt/RBH
Shell: csh
Full name Everyone
Email: nothing
Password: nothing
Password confi: nothing
Disable password: checked
Lock user: unchecked
Permit Sudo: unchecked
Microsoft Account: unchecked
SSH Public Key: nothing
Auxiliary groups: nothing added
4. I go to groups:
Group ID: 1001
Group Name Everyone
5. I go to /MNT/RBH change Permissions
Apply owner: checked
Owner: everyone
Apply owner (group): checked
Owner (group):everyone
Apply Mode: checked
Mode: All boxes checked
Permission Type:
Set Permission Recursively: unchecked
6. I go to add Windows (CIFS) Share:
In Advanced Mode:
Path: /mnt/RBH/RBH/test
Use as home Share: unchecked
Comment: nothing
Apply Default Permissions: checked
Export Read Only: unchecked
Browsable to Network Clients: checked
Export Recycle Bin: unchecked
Show Hidden Files: unchecked
Allow Guest Access: checked
Only Allow Guest Access: unchecked
Host Allow: nothing
Host Deny: nothing
VFS Objects: nothing
Periodic Snapshot task: nothing
Auxiliary Parameters: nothing
SweetAndLow
Sweet'NASty
What user is logging into the share?
Thomas.arnard
SweetAndLow thank you for your reply! It is not asking for a user name and password. I am Logged in to this computer though AD. what am i doing wrong?
SweetAndLow
Sweet'NASty
The user that logs into the share should be the everyone user and you are logging in with the ad user. That is why permissions are failing.
Or you can give others write access to the test directory.
depasseg
FreeNAS Replicant
You have your dataset set up as Unix instead of Windows, and nowhere in the permissions do you give any windows users access ("everyone" doesn't cover AD users in my experience) . Try creating a Windows dataset, and setting permissions as Owner: Root and Group: YourDomainName/DomainAdmins (or DomainUsers, if they should all have access).
Then follow this post to fine tune the permissions:
https://forums.freenas.org/index.php?threads/cifs-tips-and-tricks.34995/#post-211047
anodos
Sambassador
You probably shouldn't enable guest access on work shares. Guest access in samba can create more headaches than it's worth. Anyone with a bad username will get mapped to the guest account and cause endless tickets of the sort "I keep getting access denied".
Thomas.arnard
Thank you to all thous that have replied, you have helped out so much. But I have more questions.
So I got it work using AD users and groups. At first I put my self a the owner and a group call AR (AR has 3 users). I was able to move file to and from the share. Thing is, Other user in the AR group can't do anything with the share. I don't understand why the users in the group can't get in to the share
Also, when I change some in the GUI it change the share,vol, or data set right away, right?
Last thing, In the share window, in advanced mode, how do you use the Hosts Allow? I tried to put just the user that I wanted to have access to the share but it did not work.
Thomas.arnard
depasseg I followed the post you linked about the permissions. Every time I try to change the permissions it tells me "changes cannot be saved. access is denied" I know I am missing one little thing , I just dont know what it is.
depasseg
FreeNAS Replicant
When you changed the owner and group settings in the FreeNAS Permissions, did you apply them recursively?
Thomas.arnard
depasseg, again thank you for the help. I now have the NAS set so that everyone get in. But, when i go in to the Computer Management Console, like the post you like said to, it keeps giving me "Changes cannot be saved. Access is denied." Can you help me?
depasseg
FreeNAS Replicant
I'm not certain, but it sounds like a permission issue at the root share level.
I would create a test share and play around with the owner and group to see what works, before applying it to the real share.
