Manyakus
- Jan 9, 2019
Hi guys,
Thank you for having me in this forum.
Been looking at Freenas from some time and decided to just do it.
I've read the forum a lot and bought these so far
- SuperMicro X9SRL-F
- 4 x 16GB Samsung PC3L-12800R DDR3-1600
- XEON E5-2640V2
After reading the thread core vs speed, i realize that my CPU choice was not smart.
Should I keep it or sell it and buy another?
It was cheap around 50 $
My NAS will probably be used by two user, and plex maybe for 1 stream 1080p at any given time.
Planning on using 4x3TB one pool (Main) ZF1
Planing on using 1 big or several small drive (ZF1) in another pool (backup) - dont know yet what i want for backup
One thing I want to ask is, can I add a power switch to my backup drive so they are not always on when not in use?
They will only be on when i choose to do a backup, maybe once a week.
Does someone has any experience with these?
Is it not reccomend?
https://www.ebay.ca/itm/HDD-Power-S...h=item41e41ad21a:g:1vgAAOSwkKBbGiXg:rk:5:pf:0
I have read that the reccomended PSU is seasonic.
Is this one good for let's say 8 drives?
https://www.newegg.ca/Product/Product.aspx?Item=N82E16817151201
As for the LSI HBA card drive controller,
Can I add this later or must do it from the getco?
I might use more drive in the future, but for now i have enought sata ports on the mobo.
If adding an LSI card later, can i remove my drives connected to my mobo and connected them to the drive controller (LSI) without messing up my pools?
Never done that before, pretty sure my questions might be stupid but I want to learn and do it right from the start.
Thanks again
- XEON E5-2640V2
Thanks again
