Ahoy friends.
I have recently purchased 8 new hard disk drives in order to build up a new zfs pool. They are behind a LSI 9211 HBA, being passed-through using KVM. So FreeNAS is running in a vm.
Now i am experiencing some issue, and i don't know what happened. According to zpool status and FreeNAS alerts, 3 drives failed at the same time, at least it says
That's my zpool status output. What may have caused this issue? SMART values of each HDD are OK. Is there a way to re-add the removed devices again?
dmesg
EDIT:
It seems like i have had a power problem on my location. On different physical systems hdds also were reported as faulty at exactly the same time.
Thanks in advance!
"* Pool data state is DEGRADED: One or more devices is currently being resilvered. The pool will continue to function, possibly in a degraded state.."
pool: data
state: DEGRADED
status: One or more devices is currently being resilvered. The pool will
action: Wait for the resilver to complete.
scan: resilver in progress since Sun Mar 7 12:51:30 2021
8.42T scanned at 1.30G/s, 198G issued at 408M/s, 9.86T total
23.8G resilvered, 1.96% done, 0 days 06:54:14 to go
NAME STATE READ WRITE CKSUM
data DEGRADED 0 0 0
raidz2-0 DEGRADED 0 0 0
gptid/8d39104b-6596-11eb-a75c-8f89b0c061c4.eli ONLINE 0 0 0
gptid/9155711b-6596-11eb-a75c-8f89b0c061c4.eli ONLINE 0 0 0
gptid/86b9fa2f-6596-11eb-a75c-8f89b0c061c4.eli ONLINE 0 0 0
gptid/9285ff04-6596-11eb-a75c-8f89b0c061c4.eli ONLINE 0 0 0
38866582036668272 REMOVED 0 0 0 was /dev/gptid/9411f31f-6596-11eb-a75c-8f89b0c061c4.eli
spare-5 REMOVED 0 0 0
12219767935346166654 REMOVED 0 0 0 was /dev/gptid/9b4a1344-6596-11eb-a75c-8f89b0c061c4.eli
gptid/0cea51b3-6caf-11eb-aa19-19444082b40a.eli ONLINE 0 0 0
gptid/aab972e4-6596-11eb-a75c-8f89b0c061c4.eli ONLINE 0 0 0
gptid/ae626c03-6596-11eb-a75c-8f89b0c061c4.eli ONLINE 0 0 0
logs
gptid/080a5406-7e88-11eb-bffa-b95a0a9e4218.eli ONLINE 0 0 0
cache
gptid/9aaca0f4-7a0d-11eb-8c2d-9959dcb5e6a3.eli ONLINE 0 0 0
spares
336223762456561297 INUSE was /dev/gptid/0cea51b3-6caf-11eb-aa19-19444082b40a.eli
errors: No known data errors
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:05 with 0 errors on Wed Mar 3 03:45:05 2021
freenas-boot ONLINE 0 0 0
vtbd0p2 ONLINE 0 0 0
errors: No known data errorsdmesg
mps0: mpssas_prepare_remove: Sending reset for target ID 25 mps0: mpssas_prepare_remove: Sending reset for target ID 27 mps0: Unfreezing devq for target ID 25 mps0: Unfreezing devq for target ID 27 da5 at mps0 bus 0 scbus2 target 25 lun 0 da5: <ATA WDC WD40EFRX-68N 0A82> s/n WD-WCC7K0PY9JXR detached da7 at mps0 bus 0 scbus2 target 27 lun 0 GEOM_MIRRORda7: <ATA WDC WD40EFRX-68N 0A82> s/n WD-WCC7K6SY1409 detached : Device swap1: provider da5p1 disconnected. GEOM_ELI: Device gptid/9b4a1344-6596-11eb-a75c-8f89b0c061c4.eli destroyed. GEOM_ELI: Detached gptid/9b4a1344-6596-11eb-a75c-8f89b0c061c4.eli on last close. GEOM_MIRROR: Device swap0: provider da7p1 disconnected. (da5:mps0:0:25:0): Periph destroyed GEOM_ELI: Device gptid/9411f31f-6596-11eb-a75c-8f89b0c061c4.eli destroyed. GEOM_ELI: Detached gptid/9411f31f-6596-11eb-a75c-8f89b0c061c4.eli on last close. (da7:mps0:0:27:0): Periph destroyed mps0: SAS Address for SATA device = 4f626165bfaadf92 mps0: SAS Address for SATA device = 4f686465b794b779 mps0: SAS Address from SATA device = 4f626165bfaadf92 mps0: SAS Address from SATA device = 4f686465b794b779 ses0: da5,pass6 in 'SLOT 002', SAS Slot: 1+ phys da5 at mps0 bus 0 scbus2 target 25 lun 0 ses0: phy 0: SATA device ses0: phy 0: parent 500262d0cd87dd40 addr 500262d0cd87dd43 da7 at mps0 bus 0 scbus2 target 27 lun 0 da5: <ATA WDC WD40EFRX-68N 0A82> Fixed Direct Access SPC-4 SCSI device da5: Serial Number WD-WCC7K0PY9JXR da5: 600.000MB/s transfers da5: Command Queueing enabled da5: 3815447MB (7814037168 512 byte sectors) da5: quirks=0x8<4K> da7: <ATA WDC WD40EFRX-68N 0A82> Fixed Direct Access SPC-4 SCSI device da7: Serial Number WD-WCC7K6SY1409 da7: 600.000MB/s transfers da7: Command Queueing enabled da7: 3815447MB (7814037168 512 byte sectors) da7: quirks=0x8<4K> ses0: da7,pass8 in 'SLOT 013', SAS Slot: 1+ phys ses0: phy 0: SATA device ses0: phy 0: parent 500262d0cd87dd40 addr 500262d0cd87dd4e GEOM_ELI: Device mirror/swap1.eli destroyed. GEOM_MIRROR: Device swap1: provider destroyed. GEOM_MIRROR: Device swap1 destroyed. GEOM_ELI: Device mirror/swap0.eli destroyed. GEOM_MIRROR: Device swap0: provider destroyed. GEOM_MIRROR: Device swap0 destroyed. GEOM_MIRROR: Device mirror/swap0 launched (2/2). GEOM_MIRROR: Device mirror/swap1 launched (2/2). GEOM_ELI: Device mirror/swap0.eli created. GEOM_ELI: Encryption: AES-XTS 128 GEOM_ELI: Crypto: hardware GEOM_ELI: Device mirror/swap1.eli created. GEOM_ELI: Encryption: AES-XTS 128 GEOM_ELI: Crypto: hardware
EDIT:
Thanks in advance!
