gren236
- Jan 30, 2020
Hello!
I am trying to get L2TP/IPsec working inside FreeNAS jail, and I'm using mpd5.
Basically, I have the same issue as described in this post: https://www.ixsystems.com/community/threads/cant-get-mpd5-to-start-in-freenas-jail.13439/
So, my logs for mpd5 contain errors like this:
Ipsec and netgraph kernel modules seem to be enabled as well. Racoon is working fine.
Also, I can't use OpenVPN because I need native VPN support on MacOS/mobile devices. I would really appreciate any help and provide any helpful info.
Jan 30 11:35:53 vpn mpd: Multi-link PPP daemon for FreeBSD Jan 30 11:35:53 vpn mpd: Jan 30 11:35:53 vpn mpd: process 88367 started, version 5.8 (root@113amd64-quarterly-job-13 04:27 15-Nov-2019) Jan 30 11:35:53 vpn mpd: MppcTestCap: can't create socket node: Operation not permitted Jan 30 11:35:53 vpn mpd: LinksInit(): can't create socket node: Operation not permitted
