Moving From OMV to FreeNAS Cant port Forward.
Jousa11
Hi all, so i moved from OMV (Debian Based) to FreeNas. I have setup all my jails and am happy, I use a vpn on one jail to connect to the internet. I used to be able to use the following two rules
sudo ip rule add from 192.168.1.28 table 10
sudo ip route add default via 192.168.1.1 table 10
in OMV to allow me to access the ip using my own public ip address even though a vpn was running, i did not have to use the VPN's port forwarding features and could just use my router. is there a way to do this on FreeNas / FreeBSD
Thank You.
p.s. I know port forwarding is bad, but it is necessary.
D
dlavigne
Guest
You were used to using iptables, which is the Linux firewall. FreeNAS does not come with a firewall enabled, though port-forwarding can happen on the network's router/firewall device.
Jousa11
Ahh okay, pirt forwarding is enabled on my router but because the jail is connected to a vpn, this little iptables tri k used to allow me to remote on using my public ip and not the vpn public ip. Is there a way to install iptables on FreeNAS? I really dont want to go back to OMV
D
dlavigne
Guest
Nope, iptables is a Linux kernel thing. FreeNAS isn't meant to be be used as a firewall (which is why no firewall is included). It is meant to be protected by a properly configured firewall.
Jousa11
Thank you
