mount not working
Bill McCormick
Having troubling mounting an NFS share on a new install from a pi.
pi@mccpi /mnt $ showmount -e 192.168.212.4
Export list for 192.168.212.4:
/mnt/z1/Bill (everyone)
/mnt/z1/Data (everyone)
/mnt/z1/Media (everyone)
/mnt/z1/Public (everyone)
pi@mccpi /mnt $ ll
total 16
drwxrwxrwx 2 root root 4096 Apr 26 19:47 Data
drwxrwxrwx 2 root root 4096 Apr 26 19:47 Media
drwxrwxrwx 2 root root 4096 Apr 26 19:47 Public
drwxrwxrwx 2 root root 4096 Oct 2 23:43 zMedia
pi@mccpi /mnt $ sudo mount -vvv 192.168.212.4:/mnt/z1/Media /mnt/zMedia
mount: fstab path: "/etc/fstab"
mount: mtab path: "/etc/mtab"
mount: lock path: "/etc/mtab~"
mount: temp path: "/etc/mtab.tmp"
mount: UID: 0
mount: eUID: 0
mount: no type was given - I'll assume nfs because of the colon
mount: spec: "192.168.212.4:/mnt/z1/Media"
mount: node: "/mnt/zMedia"
mount: types: "nfs"
mount: opts: "(null)"
mount: external mount: argv[0] = "/sbin/mount.nfs"
mount: external mount: argv[1] = "192.168.212.4:/mnt/z1/Media"
mount: external mount: argv[2] = "/mnt/zMedia"
mount: external mount: argv[3] = "-v"
mount: external mount: argv[4] = "-o"
mount: external mount: argv[5] = "rw"
mount.nfs: timeout set for Sat Oct 3 18:29:34 2015
mount.nfs: trying text-based options 'vers=4,addr=192.168.212.4,clientaddr=192.168.212.5'
And there it hangs.
^Cpi@mccpi /mnt $ uname -a
Linux mccpi 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linux
What log files or other should I be looing at to debug this?
Did you try mounting the NFS share locally on the FreeNAS box to some temporary location just to see if it works?
Bill McCormick
What I found (just in the last few hours actually) was that my Cisco SG 200-08 firmware (1.6.something) had some issues with NAS. Updating it to the latest 1.0.8.3 solved the problem.
If you google "SG 200-08 nas" you'll see some others that had the same issue, which is where I got the tip from.
anodos
Sambassador
Wow. I'd expect better from Cisco, but I guess the SG switches are their 'small business' models. (Where 'small business' means 'dressed-up fancy linksys').
