I've got a FreeNAS small system setup (Fujitsu Siemens Scaleo C - Pentium 4, 512MB RAM, 1TB SATA HDD, FreeNAS on 4GB CF card on IDE adaptor) and I run FreeNAS 8.3.1 on it. I managed to install Jails on it just fine, as well as the MiniDLNA plugin. Everything works fine for a while, but after some time the system freezes! And I have no access from the Web interface. I have to either attach an external keyboard and reboot the system (I have a permanent connection to my monitor which has RGB and DMI inputs, so I use RGB for the FreeNAS system), or, I must turn it off from the mains switch and turn it back on to get it working again. The filesystem used is necessarily UFS since I cannot use ZFS for lack of Memory (the system cannot have more than 2 GB of RAM anyway).
Any idea of what is wrong?
Also, I tried to install the rescnan (Scanmedia) script proposed by a user of this thread but when I issue the command "pkg_add -r wait_on" after I have entered the Jail with the command "jexec `jls jid` /bin/tcsh" as proposed, I get the following ERROR
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/i386/packages-8.3-r elease/Latest/wait_on.tbz: No address record pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/i386/packages- 8.3-release/Latest/wait_on.tbz' by URL
Any idea about this, also?
