Maximum win users conected
jwilsont
Hi guys,
Im new on this configurations and need help with something that i think is really basic.
I setup a FreeNAS-8.3.0 and all goes well until i connected more than 5 computers.
the last computer cant log in when im trying to configure the network drive.
Is the a maximum amount of users on the CIFS?
where is my mistake?
thanks for your time and help,
George W.
Stephens
What's your authentication model? Local, Anonymous, Active Desktop? Are you allowing Guest access?
I know there's a "max connections" parameter for CIFS/Samba (smb.conf) but I can't see any way you'd be changing that, and if it's not there, it should default (which should be unlimited).
jwilsont
Hi, thanks for answering.
Im using local users, and not allowing anonymous or guest conections.
I think i should be really far from samba limits.
any ideas?
best regards,
George
