I downloaded FreeNAS-11.0-U4.iso from download.freenas.org. I randomly decided to do a SHA256 and found that the value did NOT match expected.
FreeNAS-11.0-U4.iso.sha256 states that the correct SHA256 is: 25b612ba7ef544af64094059aa87cefb69a34652aae19c51f816a49160b50919
However the one I downloaded is 4d29c3e259c3879d161b4e9f71aa16267cf97488478618c3df2a2e2b02e3d541
I copied the same download link and wget'd my Linode account, and it downloaded a version with the correct SHA of 25b612ba7ef544af64094059aa87cefb69a34652aae19c51f816a49160b50919. I copied it locally and found the same correct SHA.
I then used HxD to compare the binaries
I am able to open both of them with 7zip.
- They start differing at offset 0x113B994D
 - They end differing at offset 0x1295A614
