 - Apr 16, 2020
All,
I was hoping that someone might have an idea here. I suspect that the situation is unrecoverable - but you never know.
Yesterday I had three pools: BigPool, LittlePool & SSDPool. Following a hardware failure of a power cable to the backplane and a load of WTF type debugging I located the failed cable, replaced and now the backplane is recognised again. In the process a few cables may have moved around from the LSI Card to the backplane.
I now have 2 Pools, LittlePool & SSD Pool. BigPool has vanished completely.
Bigpool had about 10TB of data on which is backed up off site, and some (most) backed up locally - the first backup hadn't finished for some of the data
BigPool was 6 drives in 3 vdevs mirrored. The six drives are recognised, but are now all marked as unused.
Hopefully the system details are in my sig, but if not they will follow shortly.
Anyone got any ideas or should I just give up, recreate and restore.
I do have a video of the boot process which may contain clues
I have had to remove the slog drive from bigpool which was indirectly the cause of the power cable issue
Video at: https://www.dropbox.com/sh/eqo6asf5n4hlixd/AAC3-RvVxbjXNTvd6M5LO9dQa?dl=0
