blairjj
- Oct 14, 2013
Howdy,
I have the following system:
ASROCK C2750D4I / Crucial 16GB Kit (8GBx2) DDR3L 1600MT/s (PC3-12800) DR x8 ECC
Bitfenix Prodigy / Cosair 600 W PS
(5) Toshiba 2TB 7200 RPM SATA 6Gb/s 3.5" Internal Hard Drive DT01ACA200 - RAIDZ
Dual PNY 16GB USB 2.0 Flash Drive P-FDU16G/APPMT-EF
FreeNAS 9.3 (Plex. Transmission, CIF)
Last night I saw that I had the dreaded blinking red idiot light. Looking at the messages, I saw that I had a disk fail and was in degraded mode. I ordered a new disk (arrives tomorrow) and when I got home today I noticed that I couldn't ssh into the box. Went downstairs and determined the box was unresponsive, was at the 1-14 console and wouldn't respond to any of the choices. After a reboot, the zpool not longer is listed in the GUI and only 2 drives seem to be online out of the original 5.
Looking at some of the relevant posts in this section I ran the following commands:
Also reviewing dmesg shows something else ominous:
I had hoped that just replacing the drive would let me get back up and running, but I am rather alarmed that I now seem to be short 3 disks OR have a larger problem (sata controller).
Any advice / counsel or shoulders to cry on are welcome.
Thanks
[root@FreeNAS] ~# camcontrol devlist
<TOSHIBA DT01ACA200 MX4OABB0> at scbus0 target 0 lun 0 (ada0,pass0)
<TOSHIBA DT01ACA200 MX4OABB0> at scbus1 target 0 lun 0 (ada1,pass1)
<HL-DT-ST DVDRAM GH24NS95 RN01> at scbus14 target 0 lun 0 (pass2,cd0)
<PNY USB 2.0 FD 1100> at scbus17 target 0 lun 0 (pass3,da0)
<PNY USB 2.0 FD 1100> at scbus18 target 0 lun 0 (pass4,da1)
[root@FreeNAS] ~# zpool status -v
pool: freenas-boot
state: ONLINE
scan: resilvered 4.50K in 0h0m with 0 errors on Wed Dec 31 19:03:35 1969
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/09fe3642-922b-11e4-8c20-d050992ecef8 ONLINE 0 0 0
gptid/0ae1cf63-922b-11e4-8c20-d050992ecef8 ONLINE 0 0 0
errors: No known data errors
[root@FreeNAS] ~# zdb
Media:
version: 5000
state: 0
txg: 7400472
pool_guid: 3969545755668622442
hostid: 2400999328
hostname: 'FreeNAS.local'
vdev_children: 1
vdev_tree:
type: 'root'
create_txg: 4
children[0]:
type: 'raidz'
guid: 5551506481268430069
nparity: 1
metaslab_array: 35
metaslab_shift: 36
ashift: 12
asize: 9991233208320
is_log: 0
create_txg: 4
children[0]:
type: 'disk'
guid: 8452839542136952068
path: '/dev/gptid/f9ea1f47-9230-11e4-8d33-d050992ecef8'
whole_disk: 1
DTL: 278
create_txg: 4
children[1]:
type: 'disk'
guid: 12755607072554625527
path: '/dev/gptid/fa78a65e-9230-11e4-8d33-d050992ecef8'
whole_disk: 1
DTL: 277
create_txg: 4
children[2]:
type: 'disk'
guid: 10229266234416752081
path: '/dev/gptid/fb06e3ce-9230-11e4-8d33-d050992ecef8'
whole_disk: 1
DTL: 276
create_txg: 4
degraded: 1
aux_state: 'err_exceeded'
children[3]:
type: 'disk'
guid: 18357837903980992176
path: '/dev/gptid/fb8f2a82-9230-11e4-8d33-d050992ecef8'
whole_disk: 1
DTL: 275
create_txg: 4
children[4]:
type: 'disk'
guid: 7124986016943102226
path: '/dev/gptid/fc145a46-9230-11e4-8d33-d050992ecef8'
whole_disk: 1
DTL: 274
create_txg: 4
features_for_read:
com.delphix:hole_birth
com.delphix:embedded_dataAlso reviewing dmesg shows something else ominous:
ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 ada0: <TOSHIBA DT01ACA200 MX4OABB0> ATA-8 SATA 3.x device ada0: Serial Number 43Q2BHPGS ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada0: Command Queueing enabled ada0: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada0: Previously was known as ad4 ada1 at ahcich1 bus 0 scbus1 target 0 lun 0 ada1: <TOSHIBA DT01ACA200 MX4OABB0> ATA-8 SATA 3.x device ada1: Serial Number 73RTNMXKS ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) ada1: Command Queueing enabled ada1: 1907729MB (3907029168 512 byte sectors: 16H 63S/T 16383C) ada1: Previously was known as ad6
Thanks
