Locked myself out of webgui
doesntcount
I am dumb. I attempted to move over to using https only. Foolishly, in the webgui, I told it to only allow https (not http+https). I did this before verifying that https actually worked. You see where this is going...
From what I can gather, my only option is to factory restore my settings. However, I'm worried about my zvols and jails. I know I can reimport my zvols. But what about my jails. I have a half dozen jails that I've setup and I would hate to have to set those all up again.
Ideally, I'd love it if I could just ssh in and fix it so nginx allowed http connectivity again. Is there any way this is possible? Or is factory reset my only way?
Thanks for the help.
doesntcount
Man, I looked forever on the forum for something like this. Couldn't find it. Exactly what I needed. Worked like a charm. Thanks!
SweetAndLow
Sweet'NASty
In the future if you have your backup configuration file you can factory reset and upload your configuration file to undo any problems.
