Listen queue overflow/error in rsync protocol data stream (code 12) at io.c(320) [sender=3
melloa
Folks,
For sometime I notice an error on my FN(s) that could be related with rsync.
My main FN (Only used as data storage):
Build FreeNAS-9.10-STABLE-201606270534 (dd17351)
Platform Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz
Memory 32429MB
System Time Thu Jun 30 08:28:04 EDT 2016
Uptime 8:28AM up 1 day, 23:36, 0 users
Load Average 0.31, 0.24, 0.25
rsync with my back-up one (only used as back-up for the data storage):
Platform Intel(R) Pentium(R) CPU G3258 @ 3.20GHz
Memory 32428MB
System Time Thu Jun 30 08:48:59 EDT 2016
Uptime 8:48AM up 2 days, 6 mins, 0 users
Load Average 0.11, 0.18, 0.24
Noticed the errors below on the main FN:
Jun 30 08:00:00 mellonas rsync: rsync: safe_write failed to write 14 bytes to fd 3 [sender]: Broken pipe (32)
Jun 30 08:00:00 mellonas rsync: rsync error: error in rsync protocol data stream (code 12) at io.c(320) [sender=3.1.2]
[B]About the same time the back-up FN displayed:[/B]
Jun 30 08:00:00 backupnas kernel: sonewconn: pcb 0xfffff8008a860ab8: Listen queue overflow: 8 already in queue awaiting acceptance (2 occurrences)
My searches didn't provided any clues, so sorry if this is a known issue...
So my questions are:
Is this related?
Is my rsync been affected?
Is the data been affected?
Sorry for so many questions at once!
Regards,
Al
Spearfoot
He of the long foot
Are you running rsync from a script? Or are you using Rsync Tasks? Either way, please show us the details of how you're using it.
melloa
rsync tasks on main:
to rsync modules on back-up:
Spearfoot
He of the long foot
It's probably a silly suggestion... but would it make sense to set up your rsync tasks so that they don't all kick off at the same time? I wonder if what you're seeing is simply network congestion.
melloa
Not a silly suggestion and it may be the root cause. Let me make the changes and check.
melloa
Changes made and no errors in two hours. Thanks @Spearfoot for the suggestion. Will report back if anything change.
