L2ARC Graphing Bug?
scline
Hey just updated to the most recent 9.10 and am at the moment in the process of copying about 7TB of data from this ZFS pool so I can rebuild it. Currently its setup as follows:
RAM: 64GB
zPool: 5x4TB + 5x2TB (both raidz2) w/cache drive of 128GB SSD
I noticed this morning on my ARC size graph, L2ARC is currently at 1.3TB in size o_O - is there a CLI command I can run to validate this?
I'm fairly certain this was recently fixed. You're sure you're on 9.10.2-U4?
m0nkey_
Why do you have an L2ARC? You have more than enough RAM not to need one.
scline
Yea my version is
FreeNAS-9.10.2-U4 (27ae72978)
As for the L2ARC I had the spare SSD and threw it in as a cache last week as a test. Likely will remove it once I rebuild the pool (I want to have 6x4TB raidz2), majority of this storage is for plex media.
Spearfoot
He of the long foot
The L2ARC 'accounting' bug is still around as of version 9.10.2-U4, but is supposed to have been fixed in 11RC. My main system (running 9.10.2-U4) is equipped with a 240GB L2ARC SSD, but the system reports ~925GB of L2ARC:
Ah, that explains it.
