I am definitely a Noob to Freenas. I finished my NAS box over a week ago and all I have really been able to do is share info across the local network.
My hardware:
Casing: Cooler Master Glite 120
Motherboard- Asrock H61MV-ITX
CPU-Intel G1620 2.7 GHZ
RAM- 16 gb Vulcan DDR3
HD- 3 WD red 3Tb
PSU- 350w Glite power
Freenas 9.2.1.2
I have watched many how to videos as well as the Plex 9.2 which Freenas has on their site. I have also read the guide to installing Freenas each section step by step a few times.
Initially I got this message after creating my volumes, datasets, changing permissions and creating/enabling CIFS shares then clicking on Jails. ( sharing worked )
"You must configure a default route (Network->IPv4 Default Gateway)"
So I went to Global Configuration and put in my routers IP address.
Now clicking Jails works. I click configuration and browse the location of my plugins dataset and save. Now whether I choose add jail which states.
http://cdn.freenas.org/9.2.0/RELEASE/x64/jails/freenas-pluginjail-9.2-RELEASE.tgz: No address record ERROR: Failed extracting: http://cdn.freenas.org/9.2.0/RELEASE/x64/jails/freenas-pluginjail-9.2-RELEASE.tgz cannot open 'Drives/pluginjails/.warden-template-pluginjail': dataset does not exist ERROR: Failed to create ZFS base dataset
Here is my Jail configuration
Jail Root:
IPv4 Network:
IPv4 Network Start Address:
IPv4 Network End Address:
I was able to get plugins to show once and create jails but I never saw the screen to turn on plugin. So I have deleted Datasets and volumes and rebooted to start at square 1 more than once.
I hope this is enough info to start, sorry if this isn't enough info.
My hardware:
HD- 3 WD red 3Tb
Freenas 9.2.1.2
Jail Root:
IPv4 Network:
