Jails not showing in plugins after install
Rmarke
Hello
I am busy building a truenas
On first start up in the plugins i see the empty list of jails
But as soon as installed a plugin i only have a spinning circle and i can't select a installed plugin to manage it
If i remove the jail then a empty jail list is back
Does anyone have a Idea to solve this because i can't install backup because i am unable to configure admin and password
Alecmascot
Have you chosen a pool for iocage ?
Rmarke
Yes pool is there unifi controller also running
But i keep a spinning circle and i dont see the installed jail under pligins
Alecmascot
What is the output of :
iocage get -p
Rmarke
this is the output. it is in dutch opslag meens storage it is the name of the pool
truenas# iocage get -p
Opslag
truenas#
Alecmascot
Ok. That does this give you :
iocage list
What version is this ?
Rmarke
Version :
TrueNAS-12.0-MASTER-202006220424
output
truenas# iocage list
| JID | NAME  | STATE |   RELEASE    |      IP4      |
| 24  | unifi | up    | 11.3-RELEASE | 192.168.1.225 |
truenas#
Alecmascot
I guess I would go to 12.0 Beta2 before wasting more time de-bugging
Rmarke
Ok is there a way to upgrade truenas true GUI to this version
and thanks for the help so far
Alecmascot
Change the filename to Beta2
