I've finished the setup for the most part of my new TrueNAS machine and have started on my jails/plugins.
When I initially click on either Jails or Plugins it asks me for a pool to use as it's storage (I only have the 1 pool).
This is the error I get:
[EFAULT] Failed to activate data: ZFS pool "data" root dataset is locked
I've been through the root dataset options but I have no idea what 'locked' means in this context.
Child datasets and zvol's have created fine and are working as per normal.
Anyone encountered this issue before?
The full stacktrace is below:
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/jail_freebsd.py", line 1442, in activate
    iocage.activate(pool['name'])
  File "/usr/local/lib/python3.8/site-packages/iocage_lib/iocage.py", line 368, in activate
    ioc_common.logit(
  File "/usr/local/lib/python3.8/site-packages/iocage_lib/ioc_common.py", line 107, in logit
    callback(content, exception)
  File "/usr/local/lib/python3.8/site-packages/iocage_lib/ioc_common.py", line 80, in callback
    raise callback_exception(message)
RuntimeError: ZFS pool "data" root dataset is locked
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 137, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1206, in _call
  File "/usr/local/lib/python3.8/site-packages/middlewared/main.py", line 1110, in run_in_executor
  File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.8/site-packages/middlewared/schema.py", line 977, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.8/site-packages/middlewared/plugins/jail_freebsd.py", line 1444, in activate
    raise CallError(f'Failed to activate {pool["name"]}: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to activate data: ZFS pool "data" root dataset is locked
