potatosword
- Dec 30, 2018
I have a jail that I'm working on recreating after I foolishly deleted it. So I had initially created it with the name "Test" while I played around with getting things set up the way I wanted again.
Now we're pretty close to the finish line on getting it all set up but I can't get it to change its name from "Test". That is to say, the uuid changes properly in the jail interface and the commands for iocage have adapted to the new name. However, once logged into a console session I get root@Test. I have attempted to use hostname() to change the name and that works... until the next time the jail restarts and then it reverts back.
As of right now. I can't start the jail from the gui, I must use command line and I must abort once it starts hanging. Then, if I check, the jail has somehow started successfully anyway.
The only other thing I can think of is that earlier I discovered that /dev/null was missing or otherwise unable to have output sent to it. So I tried recreating it... did I fark that up?
