maximillianrg
- Sep 25, 2019
I have an old Drobo Pro that connects to my Plex Server via iSCSI. This is a direct connection meaning one end of the cat5e cable goes into the drobo and other into the NIC on the server and this has worked great for years. I also have a T-Link 48-port switch.
Drobo says if I unplug the end of the cable going into the server and plug it into the switch AND I run a new cable from the iscsi configured NIC on the server to another open port on the switch this is a supported configuration and will work.
Before doing this I have 2 questions.
1. Will I need to change any settings in the Drobo or iscsi setting on the server which is running Windows Server 2012 R2.
2. Does anyone see any issues with this change in configuration?
thank you
Max
thank you
Max
