Hello all,
I am new to the forums and I have been reading up on a lot of older materials in the past two weeks. However, I can't seem to improve my current situation and I would like to ask for your help and thoughts.
The below setup is double and identical, I have two identical freenas systems.
The hardware is the following:
I have a single pool configured, including spares and LOG:
I have tested the raw disk speed from various configurations and the above proved me the best performance and protection. These are the result from DD:
I have used iperf3 to test my network speed, and it seems fine. I am getting 1.17 Gb/s throughput when running iperf3 in server mode on host1, and in client mode on host2. Results are below:
I have a 5 TiB zvol on the pool, and this zvol is used by ESXi through iSCSI.
Now my issue is that I can only get up to roughly 500 MB/s read speed in various scenarios.
But my write speed can actually get up to 970 MB/s maximum of the array.
I have been testing with synchronisation jobs from host1 to host2, migrating VM storage from host1 to host2 from within ESXi but both won't go above 500 MB/s throughput.
When using CrystalDiskMark from within a ESXi VM, stored on host1, I can actually get the expected 970 MB/s write speed and my read speed gets stuck at 500 MB/s again. I can also see on host1 that the 10 Gbe NIC is actually getting 1.17 Gb/s throughput and during the same test I only half that speed during the read test.
Am I overlooking something/doing something wrong?
I was expecting to be able to migrate VM from host1 to host2 with at least 880 MB/s since that is the read speed of the array, and the write speed is higher so I thought that the read speed would be the limiting factor. Have I made a rooky mistake perhaps?
1 CPU: Intel(R) Xeon(R) CPU E5-2620 v4 @ 2.10GHz 128 GB ECC DDR4 RAM Storage disks: 14x 4 TB, 7200 rpm SAS - HGST 726040ALS210 Cache disks: 2x 240 GB - INTEL SSDSC2BB24 Boot disk: USB-stick 32 GB (USB3.0a) HBA: LSI SAS3008 1x 10 Gb SM231, Intel chipset 82599
6x mirror - 4 TB 2x spare - 4 TB 2x LOG (mirror) - 240 GB
Performance test using DD commands - no compression - 200 GB - sync: standard RAID Type Disk count VDEV count Space Read MB/s Write MB/s SoM 12 6 21 TB 876.45 971.61 * I did many tests, including sync: always, which I think performs fine (270 MB/s write)
[ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 10.5 GBytes 9.02 Gbits/sec 0 sender [ 5] 0.00-10.00 sec 10.5 GBytes 9.02 Gbits/sec receiver iperf Done.
