ziotibia81
- Aug 5, 2021
I'm using iscsi-scst on ubuntu machine to store some VMs backups of a virtualization environment.
Scst was build using script from https://github.com/bvanassche/scst/blob/master/INSTALL.md , whinthout any changes, and selecting dkms deb.
I'm doing a performances comparsion with TrueNAS Scale 21.5 BETA1.
My VMs Hypervisor warn about missing hardware acceleration in TrueNAS Scale iSCSI. This doensn't happens on Ubuntu machine.
Scst version is the same, and scst.conf is almost the same.
My Ubuntu scst.conf:
TrueNAS Scale scst.conf
Do you think I'm missing something?
# Automatically generated by SCST Configurator v3.6.0-pre.
TARGET_DRIVER copy_manager {
TARGET copy_manager_tgt
HANDLER vdisk_blockio {
DEVICE blockio1 {
enabled 1
filename /dev/vg0/lv-test
TARGET_DRIVER iscsi {
IncomingUser "test testtesttest"
enabled 1
TARGET iqn.2021-08.net.vlnb:test {
HeaderDigest CRC32C,None
enabled 1
LUN 0 blockio1
}TrueNAS Scale scst.conf
DEVICE utec-btr {
filename /dev/zvol/default_storage/utec-btr
blocksize 4096
read_only 0
usn fefcfe5af671000
naa_id 0x6589cfc00000099caacb4eb48956bae6
prod_id "iSCSI Disk"
t10_vend_id TrueNAS
t10_dev_id fefcfe5af671000
enabled 1
TARGET iqn.2005-10.org.freenas.ctl:utec-btr {
enabled 1
per_portal_acl 1
GROUP security_group {
INITIATOR *\#192.168.1.51
LUN 0 utec-btr
}Do you think I'm missing something?
