statikregimen
- Apr 9, 2021
Good day,
From 11.3 documentation (https://www.ixsystems.com/documentation/freenas/11.3-U1/sharing.html#iscsi-wizard), it states "For performance reasons and to avoid excessive fragmentation, keep the used space of the pool below 80% when using iSCSI.".
I haven't been able to find any more information past this. Before realizing this potential limitation, I bought 12x4TB HDDs, thinking I'd get a pool around 30TB, that I blindly assumed I could share via iSCSI (after RAID-z2 overhead)...The array ended up being 32TB, but if it is truly a big deal to use more than 80% of the array, that drops me to 25TB which is a no-go for my application.
My questions are:
1- Does this still apply (I've installed 12.2...again, docs above are from 11.3)?
2- If so, can I split the pool into 2 iSCSI shares as a workaround or does iSCSI just really need that extra space? That also leads me to wonder, if using iSCSI, do I always have to keep 20% of the pool free, with no other usage of that space possible(safe/ideal)? OR, if I want to just violate this rule, what would be the potential short/long-term consequences in more detail?
3- Any extra explanation to the documentation referenced above is bonus points
Thank you for reading, and very much for any help!
My questions are:
