Is there a way to temporarily flush or disable ARC for testing purposes?
JamesNisly
I’m in the middle of a new build and I”m currently trying to get a handle on how much of an impact a metadata special vdev will have in our particular workflow on a sample of actual client data.
To this end, I have three pools set up with the same sample data on all three. One with no special vdev, one with a metadata only special vdev, and one with a vdev with metadata and small files.
I have a small battery of common operations that I‘m trying to run some repeated tests on in order to get some semi-reliable timing numbers between the three special vdev scenarios.
The only problem is that after each test, the ARC kicks in as it should and I have to reboot between every test to ensure that I’m actually pulling data from the pools and not just getting it from cache.
Is there a way to temporarily disable ARC just to help speed this process up a little?
Pick your dataset(s).
zfs set primarycache=none pool/dataset
zfs set secondarycache=none pool/dataset for good measure.
Don't forget to set it back to all at the end.
JamesNisly
In theory, whatever was set before (default is all). zfs get primarycache pool/dataset before you set it.
It may be necessary to reboot once after the set operation as I don't think that setting will hunt for already cached items and remove them.
If you're on SCALE, maybe this would get around that:
If you're on CORE (seems to be the case from your sig), then you could (probably not very attractive) export/disconnect the pool and import it again rather than reboot.
