Hello
I'm looking for a solution to add a dataset to a jail (iocage) from a different pool.
The idea is to provide a backup machine for an other zfs pool but he can't get to my data.
I'd like to have the full zfs functionality so zfs send/receive and other zfs related commands work. So the solution doesn't have to be with iocage but I thought the concept of isolation would be the right way to do so.
What did I tried:
- "jail_zfs_dataset" is like it should be inside the jail but I can only add a dataset of the same pool (that's not what I won't because the jails are on a small SSD and these datas should land on my big RAIDZ2 pool.
- "Mount points" also doesn't work. With this option I can add a dataset of my big RAIDZ pool but I'm not able the create snapshots and do zfs send/receive inside the jail.
I hope someone does have a solution. I'm completely fine with some commands so no UI required.
Thanks in advance
What did I tried:
Thanks in advance
