I thought I would be golden for having finally added a proper NIC to my little FreeNAS rig, namely the Intel EXPI9301CT.
Well... it is not recognized by FreeNAS (9.2.1.6 Release x64) :(
The status LED just blinks green indicating no link, so I know it is powered all right.
I tried with two different cables, with which the integrated Realtek NIC works fine.
Output of ifconfig, I believe the Intel NIC should be named em0 but it is nowhere to be found:
The motherboard in my setup is Asus e35m1-i deluxe.
Please can anyone lend a hand?
[root@FreeNAS] ~# ifconfig
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether 14:da:e9:67:fc:1b
inet 192.168.100.5 netmask 0xffffff00 broadcast 192.168.100.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0xa
ether 02:b3:4c:ad:3a:00
nd6 options=1<PERFORMNUD>
member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 13 priority 128 path cost 2000
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 12 priority 128 path cost 2000
member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:73:8b:00:0c:0a
status: active
epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:f5:c0:00:0d:0a
status: active
